SOURCE: Drainage blocked on Whirlpool ADG
two things to check
if drain is plumbed nito a spigot on the sink trap, check that ther spigot and drain hose are not blocked - this is very common
also see if you can get to the drain pump and check there is nothing jamming the impellor. also if you have access to a multimeter, check if the drain pump is powered up
SOURCE: i accidentally put my ADG 4540 on prewash. it
You can continue. It will repeat the cycle and go further till end. But if detergent is required add.
In Stock
