Sharp AR-5316 Advanced Digital Imager Copier Logo
Posted on Dec 28, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sharp photocopying machine AR-5316E, I WANT TO KNOW THE PRICE AND THE WEIGHT, AND THE COMPONENTS
Tim Babcock
Level 3:
  • Sharp Master 2,794 Answers
  • Posted on Dec 28, 2008
Tim Babcock
Sharp Master
Level 3:
Answers
2794
Questions
13
Helped
1128428
Points
7249
Try this link:
http://www.sharpusa.com/products/ModelLanding/0,1058,1545,00.html
You will have to contact a Sharp dealer in your area to get the price.
I have downloaded the sharp ar-5316e software but anytime I want to print from my desktop it pop-up a message paper problem while photocopying from same printer will work
If you have downloaded the software for your Sharp AR-5316E printer, but encounter a paper problem message when trying to print from your desktop while photocopying from the same printer works fine, there could be a few potential issues to consider:
  1. Paper settings: Make sure that the paper settings on your computer match the paper size and type configured on the printer. Check the printer properties or print settings on your computer and ensure they are correctly set to match the paper loaded in the printer tray.
  2. Paper tray configuration: Verify that the paper tray is properly loaded with the correct paper size and type. Make sure the paper is aligned correctly and not jammed or skewed in the tray.
  3. Printer driver: Ensure that you have installed the correct and up-to-date printer driver for your Sharp AR-5316E printer. If you downloaded the software from the manufacturer's website, it should include the appropriate driver. Consider reinstalling the driver or updating it to the latest version to ensure compatibility with your operating system.
  4. Printer firmware: Check if there are any firmware updates available for your printer model. Firmware updates can address compatibility issues and improve overall performance. Refer to the manufacturer's website or user manual for instructions on how to update the printer's firmware.
  5. Paper sensor or other hardware issues: If the problem persists after checking the above steps, it's possible that there may be a hardware issue with the paper sensor or other components in the printer. In such cases, it's recommended to contact Sharp customer support or a professional printer technician for further assistance. They can provide specific troubleshooting guidance and help diagnose and resolve any hardware-related problems.
It's important to ensure that all connections are secure and that the printer is in good working condition. If necessary, consult the printer's user manual or contact customer support for detailed instructions specific to your printer model.
1helpful
My ar-5316e photocopier displays the number 2 followed by the letter H ... plz help
www.sharp-ro.ro/dyn_pdf/doc-AR-5316E-96.pdf
vinhco.com.vn/download/AR-5316SERVICE.pdf
http://www.eserviceinfo.com/index.php?what=search2&searchstring=AR-5316
service manual and user manuals above.
5helpful
3answers
We are trying to connect the Desk top PC so as to use AR=5316 as a printer.Need help to install the printer software. Can I get it downloaded from Sharp site. Please reply.
you may gey the driver software for AR=5316 printer install sotware inthese websites
http://nodevice.in/driver/AR-5316/get47086.html
http://ptf.com/sharp/sharp+ar+5316+printer+drivers+to+support+windos+7/
8helpful
4answers
1helpful
2answers
Sharp AR 5316 E photocopier error clearing
Try reset by pressing [#] [interupt] [C] [interupt] [1] [6] [start]
20helpful
4answers
Code H4 comes up when the sharp copier ar-5316 is switched on. it cannot be use. what shall I do to solve this problem of error code H4.
Hello sir; H4 code require reset procedure as follow;
1, press"#" "interupt" "c" "interupt" these 4 keys.
2, enter 14 , then press start
3, turn power off and back on .
3helpful
4answers
A new sharp ar 5316e photocopy machine photocopy blank
change the main charger because based on my experienced it has an arching problem
How to connect the paper feeder to a AR-5316E copier
the feeder should have two hinges
1- remove the plastic covers where they should go on hte machine
2-two types of connectors
a)a plug in in the back of the machine
b) hard wire : in this case remove the back cover of machine
there should be a ground and two plugs. in the machine there should be two wires next to the location of the plug
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
