Sony turntable need jump around while playing record.
SOURCE: Using Technics SL-B2
check the antiskating. then i don't know.. maybe the tonearm has to be calibrate
SOURCE: Seal Turntable - lousy recording!
HELLO
These cheaply-made turntables only do ONE job and that is to archive your record collection. Not surprised by the fact the record plays great on your normal turntable.
The arms on these turntables have quite a heavy tracking weight to them and you cannot adjust it. My advice to you is if you want to archive vinyl there are plenty of quality HIFI turntables out there that will blow away your Seal turntable. Don't be tempted to put a small coin on the headshell as this will INCREASE the weight and probably damage your record.
A friend of mine has one these awful Seal tables and I think they are pretty bad sound quality, also they go under many different brand names.
AVOID!
SOURCE: i have an ion turntable, when recording the tracks
First make certain the record is clean with no dust or anything on it. If that doesn't work increase the weight/pressure to the stylus, by using moving the weight on the end of the arm. Ideally it should bet set to that recomended by the cartridge maker, so check that.
SOURCE: Needle keeps jumping back 4 bars on records
CHECK ANTI SKATING SETTING SHOULD BE SAME AS STYLUS FORCE ABOUT 3.ADJUST TONEARM HEIGHT SO IT IS PARALLEL TO RECORD WHEN PLAYING.HAS THE DECK HAD NEW PHONO CABLE FITTED RECENTLY IF SO THIS WILL BE THE CAUSE GET IT DONE PROPERLY.
SOURCE: Stylus jumping on records
Recheck the arm settings. Weight and antiskate settings cause what you describe.
If it keeps sliding in one direction, it may need an anti-skating adjustment. If it jumps all over, the styus weight is probably too light (or the surface it's on isn't stable).
