20 Most Recent Canon PowerShot SX 200 IS Digital Camera Questions & Answers
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Canon PowerShot... | Answered on Nov 21, 2014
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Canon PowerShot... | Answered on May 11, 2014
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Canon PowerShot... | Answered on Jan 06, 2014
Take no more pics until you've recovered the photos, take the card out of the camera. Here's some freeware photo recovery software that should be what you're looking for:
http://camerarepair.blogspot.com/2007/12/recovering-those-accidentally-lost.html
You will need to use a flash card reader with this software. If you don't have one, get one, they're cheap:
http://www.amazon.com/s/ref=sr_st?keywords=card+reader&rs=172282&page=1&rh=n%3A172282%2Ck%3Acard+reader&sort=price
The reason this occurred is that you likely never formatted the card. The card will work fine in the beginning but eventually will corrupt. AFTER you've recovered the photos, format the card in your camera to prevent this from happening again (dig out that instruction manual to figure out how). For Canon's, go to tools menu and select the item stating the card's capacity. Then follow the on-screen prompts for a "low-level" format.
Keep in mind formatting will also TOTALLY ERASE YOUR CARD, so again only do this AFTER you've recovered the photos!
Canon PowerShot... | Answered on Nov 11, 2013
Deleting or formatting won't make the data in memory card erased permanently.
Those lost pics are still stored on the memory card, it's just invisible or inaccessible. Only the FAT or NFTS table is erased (the information about where those data were saved), but the real data are still intact there in sectors of the hard drive.
So as long as those photos are not overwritten by new pictures, it's highly possible to recover them. And the MOST Effective way is to rely on some format recovery programs.
Try Asoftech Photo Recovery program, which can recover pictures after deeply scanning the memory card to look for lost pics you accidentally deleted or formatted.
http://www.asoftech.com/apr/
Here's a format memory card recovery tutorial
Canon PowerShot... | Answered on Oct 18, 2013
See the illustrated instructions on pages 16 and 17 of this manual: http://gdlp01.c-wss.com/gds/8/0300001878/02/PSSX200IS_CUG_EN_03.pdf
Canon PowerShot... | Answered on Jul 18, 2013
Here are some troubleshooting steps for a lens error, and here is a video summary of those steps:
Canon PowerShot... | Answered on Jan 21, 2013
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Canon PowerShot... | Answered on Apr 14, 2012
There is a sensor that detects whether the flash has been raised or not. It seems like this sensor has malfunctionned and is telling the camera that the flash is not raised; this is causing the flash to be disabled.
You must rectify the problem with the sensor. Call Canon warranty support or visit the store that you purchased the camera from to get it sorted by a professional.
Canon PowerShot... | Answered on Nov 29, 2011
Restart merely means to turn it off and back on again.
Canon PowerShot... | Answered on Oct 08, 2011
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Canon PowerShot... | Answered on Sep 25, 2011
Hello
Thank you for using FIXYA!!!
This is a suggestion. If you do not feel comfortable trying it, you will need to take the unit to your nearest service centre. Feel free to let me know if you need any assistance.
The problem might be that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Canon PowerShot... | Answered on Aug 01, 2011
Canon PowerShot SX 200 IS Digital Camera Logo
105 questions posted
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
PowerShot Canon
  • PowerShot Canon
Most Popular Question
lost user operational manual get
  • Cameras
