Cant find a diagram for 92 toyota camry fuel line. Just need to know where the fuel filter is located and is there a trick to getting it off and replaced or is it a simple change out.
The fuel filter lies under the big black tube that carries the air to the throttle. Remove that black tube, only 3 screws/nuts and then u see the black filter there. Remove the nut that lies on top of the filter, then the one at the bottom. The bottom one is a bit hard to get to. Then remove the clamp that secures the filter to the car, again only 2 nuts/screws. Replace and reverse directionsThe fuel filter lies under the big black tube that carries the air to the throttle. Remove that black tube, only 3 screws/nuts and then u see the black filter there. Remove the nut that lies on top of the filter, then the one at the bottom. The bottom one is a bit hard to get to. Then remove the clamp that secures the filter to the car, again only 2 nuts/screws. Replace and reverse directions
AnonymousMar 17, 2014
92 Toyota Camry transmission does not work92 Toyota Camry transmission does not work
AnonymousMar 25, 2014
i need a schematic diagram of the camshaft to see if aspacer is used and where it fitsi need a schematic diagram of the camshaft to see if aspacer is used and where it fits
You can't post conmments that contain an email address.
On 1995 Toyota Camry 3.0L EFI DOHC 6cyl the Fuel Filter is located under hood, driver side, front side of strut tower, mounted on fenderwell in fuel line.
Hope helps. Just keep in mind that your feedback is important
and I'll appreciate your time and consideration if you leave some
testimonial comment. Have a nice weekend and thanks for using FixYa.
Stand in front of the Camry and locate the fuel filter.Open the hood of your car. The fuel filter on a 2003 Toyota Camry is located in a black container near the driver's side of the car. If you are unsure of what you are looking for, find your fuel line and trace it to a black container about 3 inches in diameter; this holds your fuel filter.Detach the fuel line from the black container, using a wrench. You might need two wrenches, one to stabilize the hex flange and the other to unscrew the fuel line. Once you have removed the gas line, you should see the fuel filter. If you remove the gas cap this will help in allowing air in the system , remove the bottom line first .Using a wrench, remove the fuel filter by taking out the screws holding it in place. Replace the old fuel filter with a new one, securing the new filter in place with the screws you have just removed.
For 1995 Toyota Camry 2.2L EFI DOHC 4cyl the Fuel Filter is located under hood, driver side, front side of strut tower, mounted on fenderwell in fuel line .
Fuel pump access port under rear seat. Line runs from there to firewall, to fuel rail. Filter mounted on left side of firewall. follow the line from the rail backwards to locate filter.
fuel filter is located at the right side of the engine, close to the belts and the shape is like a bell or just follow the fuel line. Right side or passenger side of the engine.ok
Thank you !
