Probelm with Bosch sgs66a08GB dishwaser not switching on? Checked power up to the on/off switch which is OK?Waht can it be?
SOURCE: Dishwasher won't run
Go through this link...
http://www.partselect.com/dishwasher+dishwasher-wont-work+repair.htm
SOURCE: BOSCH DISHWASHER Loss of power
check fuse in plug top,if its not that it could be door switch 30 years repairing. Close Ire....
SOURCE: Frigidare Gallery Pro Dishwasher Control Panel Power
yes the power can be bad at the trransformer and not allow power to get to the main board
SOURCE: dishwasher bosch beeping noise
Found this on the Bosch website..... see 2nd to last step
The Cycle Completion Signal
This Cycle Completion Signal is a tone that sounds to alert you when your dishwasher
finishes washing and drying your dishes. You can either disable the tone or set the volume.
To activate:
· P ress and hold the right “Cancel Drain” button then press and hold the On/Off button.
· When the light on the “Cancel Drain” button you are pressing illuminates and the tone
begins to sound, release both buttons.
· P ress the right-most “Cancel Drain” button until the tone is either at the desired volume
or is silent.
· P ress the On/Off Button. The Cycle Completion Signal is now set.
SOURCE: bosch dishwasher sps546 will not fill. switches on ok
you have to remove the cover of your unit in able to access the valve/.pump
