Question about Bosch 24 in. SHU5305UC Built-in Dishwasher
I have a Bosch SHU5315 dishwasher that doesn't turn on. I checked power getting to the machine, reset power at circuit breaker box and door lock appears to be working. Is this the power supply or computer brain motherboard?
Posted by jwappel on
Frank England
    Champion:
  • 202 Answers
Be sure lock at door is not loose switch at door if not closed wont come on ck door close switch
Posted on Mar 27, 2010
My Bosch SuperSilent dish washer stopped halfway thru a wash cycle and now does not want to come on, yes the power supply is on.
1. No power to the dishwasher
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Replace if defective (note: uncommon problem). Dishwasher Repair Help Troubleshooting and Parts
Mar 29, 2015 | Bosch Washing Machines
Any ideas what I should replace? Do I just replace the control board? Would that one relay cause the whole dishwasher to have no power?
If you have a multimeter set to continuity and see if it burnt out you might be able to replace it at an electronics part place also see if there are any fuses in there
Jan 26, 2015 | Bosch SHU5315UC Dishwasher
I have a shu43 bosch dishwasher and the whole machine is dead. No power. The circuit breaker is good but I would have to pull the dishwaher out to check the outlet. Is there an internal fuse?
There is no internal fuse (at least I've not seen or replaced any) on Bosch dishwashers. The most typical problems for Bosch are: 1) one of the power cord connections to the internal wiring is corroded and doesn't make a contact; or 2) the power button has failed.
The number one is so far the most common problem. To check: Turn off the power to the dishwasher by any means necessary. Remove the kick panel on the bottom. There should be a small metal box with power cord and 2 or 3 wires coming into it. Remove screw(s) holding the cover on that box. There should be 2 or 3 wires connected to the power cord wires by wire nuts. Any burnt insulation or wire nut will be the problem area. Cut burnt wires, remove 1/2" of insulation and clean of both connecting wires to bare copper. If you have an electrical contact grease - apply to copper. Install new wire nut.
Good luck,
Vlad with First Choice Appliance, Sacramento, CA
Jun 28, 2012 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher makes noise but doesn't start
When you start a wash cycle on your Bosch dishwasher and it does not work, stay calm. It could be something simple, especially if you just installed it. Make sure the power cord is connected properly and a circuit breaker did not trip. How to Troubleshoot Bosch Dishwasher That Doesn Fill With Water
Sep 25, 2017 | Bosch Dishwashers
Wash cycle stopped with water in the bottom. Seems like there is no power. Can't get lights on cycles buttons to turn on. Power button does nothing. Checked circuit breakers. All are on. Lights and outlets...
Check the wiring in the units junction box. Its located at the bottom right corner. You will likely find melted connectors. If so, you need to cut the wires back and replace these connectors. Make sure you turn the power off before doing any of this work of course. Good Luck.
Jan 14, 2011 | Bosch 24 in. SHX46A05UC Built-In...
Hi! My Bosch began by tripping the breaker during the cycle (several times if I could get it to reset) and now will not start at all. Even when the dishwasher is off I cannot reset the breaker unless I...
Hello
Welcome to Fixya.
Based on your post,"...Even when the dishwasher is off I cannot reset the breaker unless I kind of move the machine around a bit. Sometimes it pops the breaker just closing the door..."
These are the most common reason for these Bosch dishwashers not having power.
#1
I would start by first shutting off the breaker. Then removing the kick plate ( access panel at the bottom ) and checking the wiring at the junction box for the dishwasher 120vac supply line.
Remove the murret's and visually inspect the wire for "resistance burn" and strip the wires back and install new fastener's if necessary to repair.
i.e.
This is actually quite common to find a wire connector come loose due to improper fastening and once the unit is in use for a while the connections heat & cool, become loose from normal operating vibrations and burn up from all the added heat caused by "resistance".
#2
A wire severed inside the door panel, hence the breaker trips by just moving the door in an open/close motion.
Check thoroughly in this location...
The end result is tripping the breaker and no power to the controls.
Check it out and post back what you find. Thanks for visiting "fixya" and please take a moment to rate the solution/suggestion provided here for you.
Good luck.
Regards,
Macmarkus :)
Oct 06, 2010 | Bosch SHU9915UC Dishwasher
Bosch Dishwasher will not power on
I saw my repair man do the following, which you might try...
Open the door and simultaneously press & hold down the power button with the 2 buttons used on your model to "Cancel & Drain." If the unit comes on it now is in self-diagnosis mode. Release the buttons and close the door. The unit should start to fill with water. Press the power button to exit the mode.
Jun 28, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Whirlpoool dishwasher not turning on model du1050
Make sure you have power to the dishwasher, check circuit breaker. If circuit breaker is ok, then remove toe panel at bottom front of machine, on the right hand side is where the power cable goes into a little metal box. Turn off circuit breaker to kill power to the dishwasher, remove electrical box cover and check to make sure that the wire nuts are tight. Reapply power and test. If still no go then remove tech service sheet from toe panel insulation, get yourself a multi-meter and start test individual components until you find the one that is bad. Hope this helps.
Dec 11, 2008 | Whirlpool 24 in. GU3200XTP Built-in...
Bosch 5315 dishwasher
A fuse may have blown or a circuit breaker tripped. Replace fuse or reset circuit breaker at your fuse box/breaker box windman
Jan 30, 2006 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch 24 in. SHU5305UC Built-in Dishwasher Logo
783 people viewed this question
Top Bosch Dishwashers Experts
Michael Thomas
Michael Thomas
peter gittos
peter gittos
Marvin
Marvin
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
