It sounds like there might be an error with the internal software of your Roland Camm-1 Servo GX-24 vinyl cutter. Here are a few troubleshooting steps you can try:
Check the manual: Refer to the user manual to see if there is any information on what the "Report" message might mean. The manual may also have instructions for resetting the machine or troubleshooting common issues.
Check the connections: Ensure that all the cables and connections are secure and properly connected. Also, check if the power source is working correctly.
Check the firmware: It's possible that the firmware of the machine has become corrupted or outdated. You may need to update the firmware by downloading the latest version from the Roland website.
Perform a factory reset: If nothing else works, try performing a factory reset on the machine. This will erase all the user settings and restore the machine to its original factory settings. Refer to the user manual for instructions on how to perform a factory reset.
If none of these steps work, you may need to contact Roland customer support or a qualified technician to diagnose and fix the issue.
ERROR 2:
Appears if the number of parameters differs from the permissible number.
You can download the EasyCut Pro software from https://www.easycutpro.com/ and give it a try.
This vinyl cutting software works great with Roland GX-300 CAMM-1 Pro Vinyl Cutter.
try easy cut studio from https://www.easycutstudio.com/
I've used it to cut a variety of vinyl decals using my own Roland GX-300 cutter and other artwork. It it completely compatible with my Roland GX-300 machine and very easy to use.
Material not aligned or wrong thickness... Blinking means something is not right. Try taking the material out and see if it changes, things like that, troubleshooting....
