Question about Roland VersaCAMM SP-540V
Carriages are disconnected in roland sp540 - Roland VersaCAMM SP-540V
Posted by thanlav on
Armand Potgieter
    New Friend:
Posted on May 06, 2015
Carriage are disconected
How to stop BN20 from beeping due to one empty ink cartridge. Need to purchase replacement.
Aug 05, 2014 | Roland VersaCAMM SP-540V
Distorted printingting
hello
try to clean the Encoder strip of your sp540, gently with alchool isoprophilic
i add a video explaining (the procedure and the result is the same for sp540) i hope this is helpfull. good luck
Feb 04, 2014 | Roland VersaCAMM SP-540V
I have roland verscamm sp-540v when i switch on then error comes service call 0101
the 0101 error in sp540 is the Limit Position Initialize has not been done. you find videos on you tube that can help you to do the limit position operation. (you have to enter in Service Mode Menu) its easy to do it yourself. i hope this help.
Dec 24, 2013 | Roland VersaCAMM SP-540V
SETUP SHEET PINCHROLL ERROR INVALID IF RIGHTPOS
i had a similar problem with my sp540 and the solution was the strip (the electrical one, that is connected to the head, broked)
have to be replaced. and everything goes ok .good luck
Jan 15, 2013 | Roland VersaCAMM SP-540V
I have an hp c 3180. Changed the black ink cartridge, the carriage went left where it is now lodged... I need to get the carriage out where I can check to see if the cartidge is properly seated.
Hi Richard,
Please follow the steps below to make sure that the carriage can move freely and is properly seated. Check the carriage path. Press the Power button to turn the product on, if it is not already on. Open the cartridge access door. The carriage might try to move into the access area at the right. Allow the carriage to move to that position.
1. Open the cartridge door.
2. Wait until the carriage is idle and silent.
3. Without turning off the product, disconnect the power cord from the rear of the product.
WARNING: In the following steps, you move parts by hand. You must disconnect the power cord from the rear of the product to eliminate the risk of an electrical shock and to reset the paper-feed mechanism.
4. Disconnect the power cord from the wall outlet or power strip.
5. Look inside the product to see where the carriage is stuck, and then check for any torn paper or other objects that might restrict the carriage.
NOTE: You might need a flashlight to illuminate areas for proper viewing.
6. Remove any loose paper or obstructions found.
7. Reach inside the product through the cartridge door, and then manually move the carriage.
8. If the carriage is stuck on the right side of the product , move the carriage to the left side of the product.
9. If the carriage is stuck on the left side of the product , move the carriage to the right side of the product.
10. If the carriage is stuck in the middle of the product , move the carriage to the right side of the product.
11. Make sure the carriage moves freely across the width of the product. Firmly push the carriage to the left side of the product, and then to the right side.
12. Close the cartridge access door. Close the cartridge access door
13. Reconnect the power cord to the rear of the product.
14. Plug the power cord into the wall outlet or power strip.
15. Press the Power button to turn on the product.
Hope it helps.
Thank you for using FixYa.
Dec 26, 2011 | Office Equipment & Supplies
My officejet 5610 says "carriage jam. Open Door etc. I can't find a door to the carriage.
Hi!
here are some solutions for your carriage jam error.
1. Clear any jam...remove loose paper.
2.Clear the jam from the back of the printer
turn off the printer...remove the rear access door..
pull the paper out of the roller and return the rear access door.
3. Clear the paper jam from the front of the printer..while printer is on.. open the carriage access door..
disconnect the power cable from the back.. remove the paper output tray.
look inside the product..check for torn papers..gently pull out the paper from the roller...return the paper output tray and the carriage access door. plug the power corn and turn on..
4. Make sure the carriages move freely...while the printer is on.. open the carriage access door.
disconnect the power cord from the back..remove the paper output tray...look inside if the carriage is stuck and if there is no papers or object that restrict the carriage to move..return the output tray.. return the carriage access door...
And lastly after doing this steps try to reset the printer and try to print..
To reset the printer....press the power button to turn on the printer..disconnect the power cord from the product..disconnect the power cord from the wall outlet.. wait for 15 seconds.. plug the power cord to the wall socket....plug the power cord at the back of the printer.. press the power on of the printer.. try to print the test page...
Good luck! hope this solve the problem
Much appreciated if you rate this help.. thanks
May 23, 2010 | HP Officejet 5610 All-In-One InkJet...
What is a carriage jam
3. Clear the paper jam from the front of the printer..while printer is on..open the carriage access door..
look inside the product..check for torn papers..gently pull out the paper fromthe roller...return the paper output tray and the carriage access door. plugthe power corn and turn on..
4. Make sure the carriages move freely...while the printer is on.. open the carriageaccess door.
disconnect the power cord from the back..remove the paper output tray...lookinside if the carriage is stuck and if there is no papers or object that restrictthe carriage to move..return the output tray.. return the carriage accessdoor...
To reset the printer....press the power button to turn on theprinter..disconnect the power cord from the product..disconnect the power cordfrom the wall outlet.. wait for 15 seconds.. plug the power cord to the wallsocket....plug the power cord at the back of the printer.. press the power onof the printer.. try to print the test page...
http://www.fixya.com/support/t6088190-hp_7400_displayshttp://www.fixya.com/support/t6088190-hp_7400_displays
May 10, 2010 | Office Equipment & Supplies
Have a Roland SP 540 V Eco Sol MAx printer/cutter. Magenta/Yellow print head clogged (hadn't been used in a few weeks) can't seem to get the ink to flow in those heads! Any idea other than head...
you should have to use the syringe method to **** the ink before anything, then make a powerful cleaning, test, you may have to do it several cleanings and should be solved.
Jan 08, 2010 | Office Equipment & Supplies
I want to know how involved is it to change the roland versacamm sp 300 print heads
Checkout the guide to replace the pump at:
http://www.decaldesigns.co.uk/img/Pump_replacement_procedure_sp_e.pdf
It also has the instructions to move Head Carriage
Sep 03, 2009 | Office Equipment & Supplies
Roland sp-540v will not print even though the print head moves back and forth as though it is printing. This just started today. Yesterday it worked just fine.
you have a ink problem first check your pump is working read your manual cleaning prints . if heads are blocked get your old ink in waste and pour small amout on the heads to unblock them you might have to do it a few times put back together leave overnight and do a powerful clean and you may have to repeat  afew time read your manual its shows you how to pull apart
Jul 28, 2008 | Office Equipment & Supplies
Roland VersaCAMM SP-540V Logo
2,094 people viewed this question
Top Roland Office Equipment & Supplies Experts
Ekse
Marvin
Marvin
Are you a Roland Office Equipment and Supply Expert? Answer questions, earn points and help others
