How do i install a power steering pump oon a 92 honda accord
Hey, here's the procedure, disable air bag, if equipped w/ one, disconnect the pump return hose from the reservoir and place the end in a large container. Plug the port in the reservoir. Start the engine and turn the steering wheel lock to lock several times, until fluid stops running from the hose. Turn off engine immediately. Re-attach hose. Disconnect the inlet and outlet hoses at the pump. Remove the drive belt. Remove the mounting bolts/nuts and remove pump.
Install in reverse order. Adjust belt tension,fill ps reservoir and bleed any air from the system (to bleed air from system, fill reservoir, start engine and allow to idle, turn wheel from side to side all the way several times. Shut off, fill if necessary.
. Tighten bolts to : Thru bolt 30 ft lbs., mounting nut 16 ft lbs.
how to, do you have to remove serpentine belt first
electric steering rack is not self centreing and torque sensor has been anylised as at fault. Does this sound feasible.
