Error code bad throttle body ,replaced throttle body , how to reset error code
Soft reset disconneting the negative battery cable few minutes; if the code come back again, its possible that you have some problem with the sensor, wires or harnesses connections.
Keep in mind that sometimes will need OBD scanner tool to reset or delete all stored codes.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
SOURCE: 2000 mazda miata r&r throttle body
se if egr is controled by vacium or electric
if it is by vacium then locate the egr solenoide and make sure it has vacium in one hose w/ engine runing if it does then replace solenoide
SOURCE: 2008 Honda Civic si
Go to any auto parts store and you can use the meter to see what code it comes up with, The meter has the codes on it and will tell you why the check engine light is coming on.
SOURCE: 1993 Volvo 940 error code 232
2-3-2* Fuel trim (lambda control) too lean or too rich at idle }If too rich: high fuel press., leaking injector } various driving problems Fuel trim (lambda control) too lean at idle Oxygen sensor
SOURCE: error code 6 on radio. 1997 accord
reset the radio code
Testimonial: "cool thanks man. how do u reset radio code "
SOURCE: on a 04 camry with 2.4 ltr engine, can I replace
I think the terms "Throttle Positon Sensor", TPS and "Throttle Body" can be misleading at least in regards to the 04 Camry.
My 04 Camry gave a diagnostic reading of P2121 for my problem "Throttle PEDAL position switch D circuit". However, we changed out the complete Throttle Body/TPS (Toyota Part #22030-0H020) that did NOT fix problem.
The 04 Camry TPS Electronic Module "Throttle Positon Sensor" is factory assembled and riveted to the side of the throttle body. The only way to service/inspect it would be to cut off or drill out the rivets. Not sure you could open the darn thing if you got it off, but that seems to be the only way Toyota sells them!!
Hopefully a new Throttle PEDAL Position Sensor (Toyota Part # 78010-33010 PEDAL ASSY, ACC)
will fix it. This is located under the dash near the accelerator pedal.
So, now I would recommend FIRST to replace the "Throttle PEDAL Positon Sensor" (it is much, much cheaper) and then the Throttle Body/TPS assembly!! Unless of course, you get a diagnostic code as you did for "faulty throttle body!!
