Question about Breville ESP8XL Espresso Machine
I grinded my coffee in a new store, and did not realize that the coffee was too finely ground. I tried it on my breville, and now nothing happens when I try to make coffee. The 2 cup filter is fine. I woudl like a way to clean out the 1-cup filter. Thanks
I'm not sure you can. I did exactly the same thing, the very first time I used it -- I phoned Breville support and they told me to try soaking the filter in 2 tsp of baking soda dissolved in a cup of warm water. Which kinda seemed to work, although it was bit occasionally reluctant to give me my damned coffee.
I struggled on with it for maybe a year, but then the rubber seal around the bit the filter connects to blew out (with rather dramatic results). I think the extra pressure of the blocked filter did more damage that I suspected.
I got it serviced and they replaced both the seal and the filter. Worked great after that...
...until last week, when water started pouring out where no water should pour. Turns out that the black lock block that the filter holder goes into has developed a crack.
Looks like another trip to the service agent for me.
In short, you could try cleaning the 1-cup filter, but I would reccommend giving it up as a bad job and just buying another.
Before It Is Too Late.
(Signed, The Harbinger of Doom. Sorry about that.)
Posted on Feb 02, 2008
Aug 10, 2012 | Cuisinart Dgb-900BC Grind & Brew Thermal...
Jan 01, 2012 | Hamilton Beach BrewStation 47665
Aug 24, 2017 | Keurig Elite B40 Coffee Maker
Oct 16, 2009 | Breville Die Cast 800ESXL Espresso Machine
Jul 30, 2009 | Miele CVA615 Espresso Machine
Jun 27, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
May 21, 2009 | Bunn NHB Coffee Maker
Feb 20, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Jan 11, 2008 | Cuisinart DCC-1200 Coffee Maker
Oct 22, 2007 | Breville Die Cast 800ESXL Espresso Machine
Jun 08, 2014 | Breville ESP8XL Espresso Machine
274 people viewed this question
I have had trouble with coffee ground too fine. The wat couldn't pass through & built up with pressure & splattered everywhere when released. It now does it with my regular coffee. i can't work out what the probelem is because the water is flowing fine. It sounds as though the filters themselves are clogged so I will give them a good soak as & clean to see if this help. Sounds hopeful because I don't think there's anything else wrong & the machine has always worked really well.
BH
The rubber seal around the bit the filter connects to blew out this am. Obviously the extra pressure of the filter that blocks quite often, did the damage. Water is pouring out and can't make coffee no more. Do you know how I can find service agents to replace the filter and fix it? Thank you kindly.
hi
my machine is leaking and it looks like its from the rubber ring area. i took it off, cleaned it and put it back tightly and it still does the same. after i checked the ring it seemed to be fine with no leaks.... could it be excess pressure causing the water to spill over the sides of the filter? how much would it cost to have parts replaced?
thanks
