Please send answer to [email protected]
This is a very easy simple way to fix coffee grind overflow. I began using another filter on top of the coffee grinds in the basket. This prevents splattering when aggressive brewing or using more than the usual weak coffee measuring, I like mine strong but not bitter. Fixed the splatter and coffee grounds in the dispensing tank. Coffee filters are CHEAP at the dollar store.
SOURCE: ? Am I trying to use coffee ground TOO FINE
The grind setting on machines are not standard. Your grind is far to fine. On the Gaggia grinders the setting of 4 works well for Espresso and 8 for regular drip. I suggest you buy a small amount of 5 and 6 for espresso to test. Be carefull that the grind is not too course as you will have very little crema on your espresso. I always switch my machine on and let it warm up for about 10 minutes as this improves the crema.
SOURCE: Waring Pro Coffee Maker has a water flow problem
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check
if water is dripping right at the center of the filter, if it is
dripping on one side because the orifice is clogged, that can result in
weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure
that you are not leaving the machine brewing for a time that is too
long, and Italian coffee cup is very small, approximately one regular
shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This
are the trickiest ones, you need art and practice to get a good
espresso with a Moka, but when you learn, the result is better than
what you may get with an home electrical espresso maker.
The frame
on the hob must be not too strong, and the mixture coarse but well
pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
SOURCE: kitchen aide coffee maker model #KCM534 shows an
An ERR 2 may be cleared by a simple reset of the coffee maker. This
means unplugging the unit and plugging it back in. When powered back
on, select a brew function to see if the error reappears.
If it does, ERR 2 indicates an internal error with the computer of the
warming plate. This may be covered under Kitchenaid's 1 Year Hassle
Free Warranty. I would advise you to call Kitchenaid Customer Service
to see what options are available to you. Repair is not recommended, as
it is not cost effective for the company or the consumer.
Their toll-free telephone number is 1-800-541-6390.
SOURCE: I have a Saeco Magic De Luxe. I am having a problem intermittent
Could be the pump not providing enough pressure to force the water through the coffee. When using beans or preground, can you still hear the pump function?
SOURCE: I cant get the coffee grounds container out. I
Be very careful if you are too rough then it can uncilp the flap, try and open the tray a little then with a pencil lift the grounds container up and slowly ease the tray out
