2000 Cadillac Catera Logo
Anonymous Posted on Sep 03, 2012
ABS and TC light on. Speedometer and odometer are not working
Sometimes the speedometer, and odometer are working fine, but after I drive a bit the ABS and TC lights will come on...sometimes they go off again. From what I have read I need to replace the ABS module...does anyone know what ABS a Catera 2000 needs? and how do I replace it?
Stephen
Level 3:
Top Expert:
  • Cadillac Master 21,873 Answers
  • Posted on Sep 04, 2012
 Stephen
Cadillac Master
Level 3:
Top Expert:
Answers
21873
Questions
0
Helped
6210453
Points
67230
If the speedo and odometer are not working it could be the speed sensor in the transmission. And the speed sensor could also knock out the ABS and traction control systems.
Have you had the body computer scanned for trouble codes ?
  • Anonymous Sep 05, 2012
    No, but from what I have read I need to replace the ABS and I have no idea how to do that...
5 Related Answers
Lorenzo Lamanna
  • 113 Answers
  • Posted on Jul 25, 2010
SOURCE: my '99 catera speedometer doesnt work and the
You need to replace the traction control module located on the ABS pump. There are places in the US where they will rebuild it for you with warranty for about $150.
Its tricky to get off (you need to remove the rad hose between the battery and the pump to get to it, but don't disconnect the ABS module, just the TC module mounted at end of the ABS unit (has a bunch of brake lines coming out if it).
The power steering is variable assist, relative to the speed of the vehicle, so if the speedo doesn't work, then the PS won't and you should have TC and ABS lights on. The electrical connectors to the module are tricky to remove. don't force them. One connector has a sliding lock bar.
Anonymous
  • Posted on Dec 29, 2008
SOURCE: ABS and TC light on, speedometer and odometer not working
I have the 2000 Cadillac Catera Sport and I had the same problem. ABS, TC light and no speedometer and odo. I thought it was an electrical problem however I solved the problem by refurbishing the ABS Module. If you bring to the dealer it will cost you $3,000. You can have your ABS module rebuilt try modulemaster.com they do it for about $200 I believe. I got mine fixed because a friend of mine removed them and soldered some loose connectors together. All it cost me was a case of beer! It worked for my car just a suggestion for you guys. My ABS Module was a Bosch 5.3. Hope this helps!
Anonymous
  • 1985 Answers
  • Posted on Jan 07, 2010
SOURCE: I have a 1997 Catera my ABS/TC light comes on
have the codes read from your car,have them check history codes since it is not a hard code.
Anonymous
  • 4 Answers
  • Posted on Feb 25, 2009
SOURCE: I have a 1998 Cadillac Catera and the speedometer
ok your cable for the speedometer,odometer may be broken is the radio stock or aftermarket
Anonymous
  • 11 Answers
  • Posted on Jul 22, 2008
SOURCE: 2000 catera frequent speedometer not working
Hi, in ure case the abs ecu is obviously a main ecu. it sounds like you have a can communication problem where your system detects hi speed can malfunction, or interferance, measure your end of line resistance=120ohms and network nominal value should be 60ohms voltages between can hi and low should ad up to 5v , or to ground eg. can hi=2.7v then can low should measure 2.3v. if either one of these measurements dont add up you know which cercuit is at fault.
It might even be a vehicle speed /wheelspeed sensor contaminated or damaged component causing system shut down.
1994 Nissan pu speedometer quit working
SPEEDOMETER TROUBLESHOOTING
Can be loose speedo wiring connectors under instrument panel or its issue with speed sensor on transmission.
I suggest you to go through help links mentioned below with appropriate solutions to confirm the problem :------
How to trouble shoot speedometer?
http://schematicsdiagram.blogspot.com/2011/06/speedometer-not-working.html
1996 fiat bravo speedometer not working?
http://technoanswers.blogspot.com/2012/01/1996-fiat-bravo-speedometer-not-working.html
Speedometer works but odometer not working?
http://technoanswers.blogspot.in/2012/01/speedometer-works-but-odometer-not.html
Speedometer runs backward?
http://technoanswers.blogspot.com/2012/01/speedometer-runs-backward.html
Warning lights on and speedometer died?
http://howtobyme.blogspot.com/2011/08/warning-lights-on-and-speedometer-died.ht
Speedometer not working on 1993 Ford F350?
http://repairhelpcenter.blogspot.in/2012/02/speedometer-not-working-on-1993-ford.html
ABS & Brake lights warning indicator steady on dash and speedometer not working for Dodge Ram?
http://howtobyme.blogspot.com/2011/11/abs-brake-lights-warning-indicator.html
Vehicles Cluster panel Not reading Miles?
http://schematicsdiagram.blogspot.com/2011/12/vehicles-cluster-panel-not-reading.html
Odometer works properly but speedometer works intermittently?
http://technoanswers.blogspot.com/2012/01/odometer-works-properly-but-speedometer.html
These will help.
Thanks.
2answers
Speedometer doesn't work
For speedometer related issues,the help links are provided below.Click the link below to go through its details :----
why speedometer not working? http://technoanswers.blogspot.com/2012/01/1996-fiat-bravo-speedometer-not-working.html
Speedometer works but odometer not working? http://technoanswers.blogspot.in/2012/01/speedometer-works-but-odometer-not.html----------- Speedometer runs backward?
http://howtobyme.blogspot.com/2011/08/warning-lights-on-and-speedometer-died.html
ABS & Brake lights warning indicator steady on dash and speedometer not working?
Odometer works properly but speedometer works intermittently? http://technoanswers.blogspot.com/2012/01/odometer-works-properly-but-speedometer.html
How odometer works in cars?
http://technoanswers.blogspot.com/2011/11/how-odometer-works-in-cars.html
Speedometer not working on Ford?
This will help.
Thanks
Which fuse do i replace for the speedometer?
For speedometer related issues, the help links are provided below. Click the link below to go through its details: ----
Speedometer works but odometer not working? http://technoanswers.blogspot.in/2012/01/speedometer-works-but-odometer-not.html ----------- Speedometer runs backward?
This will help.
Thanks
Where is the speedometer sending unit located
This will help.
Thanks
2helpful
The speedometer does not work
This will help.
Thanks
What does it mean when the speedometer goes out?
This will help.
Thanks
3helpful
2answers
Car speedo & odometer sometimes work OK, other times not at all.
Most likely a speed sensor is going bad (most cars and truck do not use mechanical speedometer cables anymore) most sensors are located near the differential in rwd cars or near the drive shaft on the transmission. Best bet is to get a Haynes manual for your car to help locate the speed sensor. Remove it and take it to the auto parts store so you can visually compare it to the replacement. Install the new speed sensor and it should restore your speedometer and odometer.
1helpful
2answers
Odometer inop and speedometer erratic over 50mph
Yes your speedometer, and odometer are controlled by your speed sensor.
2answers
The speedometer and odometer do not work on my 98 cadillac catera. I had the sensor in the transmission changed, but still nothing. I have reason to believe the guy I bought it from turned the odometer...
I have a 2000 Catera that when I changed the electronic brake control module all warning lights went off, speedo and odo worked. New EBCM is $2000 Cdn I got mine used for 170. also it can be re built at modulemasters.com for $160. Not sure about the dash light tho.
Rob
16helpful
3answers
Top Cadillac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Cadillac Expert? Answer questions, earn points and help others
