I was hit with a trojan last night, and took care of it; but now my wireless will not turn on with using my FN + f2..I need help quick please!
Try reinstalling the driver Ramkil Computer Repair Solutions Phone: 801 380 5973 Email:[email protected]
SOURCE: Fn +F2-F3-F4-F7-F11-F12 how do you use
dear bdgdag,
please visit the following site for more information about the functional keys.
remember to vote for me if its useful
http://www.aarp.org/learntech/computers/howto/a2003-03-28-functionkeys.html
SOURCE: Can not turn on wirless capability using Fn & F2 keys
have you tried restarting see if internet picks back up if not try this
control panel
network connections
right click your wireless
if you see enable the click
if not then click repair.
please let me know if this solved if not we'll go to the next step
SOURCE: Fn F2 combo does not turn on wireless internet on Gateway 7405GX
There should be, i.e as in via the Network Connections in Windows. Check i Device Manager if ALL is well ad Enabled, i.e the Wireless Device.
Also you might want to enable it via BIOS setup, especially if it is Onboard and not a Plug-in Device for Wireless Connection such as a PCMCIA Wireless NIC, etc etc.
Right Clicking on Icons often reveals many shortcuts to what you can do, eg Properties of the Wireless Network Connections Enable, Disable, Status, Repair and so on.
Take your time and learn what hidden alternatives there are to navigating thru Windows.
Hopefully you'll be able to fix the problem if not already done so.
SOURCE: how to turn on hardware switch to enable wireless
What make, what Model? One of the least standardized items in computing is what/where the wireless switch is.
SOURCE: can't enable Dell Wireless 1390 WLAN Mini-Card
I had the exact same problem and went through the same steps that he did. It was only when I searched for a physical wireless switch (on the left side of my Dell D630) that the problem was solved. I didn't even know it was there and must have inadvertently knocked into the off position.
Maybe you don't have your wireless turned on. Look on
both sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can toggle
the wireless on or off. Normally you would Press and Hold the FN function
key located at the lower left of the keyboard, then hit the correct F1 thru F12
key that toggles the wireless. The correct F1 thru F12 key to hit will
have the wireless signal icon )))) on it. Or it might have the icon of a tower
with the wireless signal icon )))). Normally the screen will display
Wireless On or Wireless Off when you toggle the wireless.
Some laptops might have a wireless button instead of a wireless switch located above the keyboard or on the front or sides.
