Hello Dylan, for what you are saying, your TV has suffered a shock of tension, it is probable that the current input fuse has been burned or in the worst case the power supply has been damaged.
If you are going to see if the fuse is burned, just replace it with one of EQUAL VALUE, neither bigger nor smaller
If you replace it and it burns, I suggest you look for a specialized technical service
I hope you can solve the problem
Greetings Franco Dosil
Hola Dylan, por lo que comentas, tu televisor ha sufrido un golpe de tension, es probable que se haya quemado el fusible de entrada de corriente o en el peor de los casos se haya da?ado la fuente de alimentacion
Si vas a ver si el fusible esta quemado, Solamente reemplazalo por uno de IGUAL VALOR, ni mas grande ni mas chico
Si lo reemplazas y se quema, te sugiero busques un servico tecnico especializado
Espero que puedas resolver el problema
Saludos Franco Dosil
http://www.hdtvsolutions.com/pdf/tel_dow_LC42_46_52D64U.pdf
