Question about Sharp Televison & Video
Had a very quick on and off power outage. My Sharp AQUOS (LC-52D64U) won’t turn back on with the manual button. I’ve tried unplugging it and plugging it back it and nothing. I have no lights on the TV lighting up.
Posted by Dylan Ostetto on
  • Dylan Ostetto
    Dylan Ostetto May 26, 2019
    Thank you, turns out the power supply is damaged, and i'm going to replace the whole board. Thank you
  • Franco Dosil May 27, 2019
    Hello Dylan, well you could determine where the problem is, I hope you will soon enjoy your Sharp
    Greetings Franco Dosil
    Hola Dylan, me alegro que pudo determinar donde esta el problema, espero que pronto disfrute de su Sharp
    Saludos Franco Dosil
Franco Dosil
    Top Expert:
  • Sharp Master
  • 10,535 Answers
Hello Dylan, for what you are saying, your TV has suffered a shock of tension, it is probable that the current input fuse has been burned or in the worst case the power supply has been damaged.
If you are going to see if the fuse is burned, just replace it with one of EQUAL VALUE, neither bigger nor smaller
If you replace it and it burns, I suggest you look for a specialized technical service
I hope you can solve the problem
Hola Dylan, por lo que comentas, tu televisor ha sufrido un golpe de tension, es probable que se haya quemado el fusible de entrada de corriente o en el peor de los casos se haya da?ado la fuente de alimentacion
Si vas a ver si el fusible esta quemado, Solamente reemplazalo por uno de IGUAL VALOR, ni mas grande ni mas chico
Si lo reemplazas y se quema, te sugiero busques un servico tecnico especializado
Espero que puedas resolver el problema
http://www.hdtvsolutions.com/pdf/tel_dow_LC42_46_52D64U.pdf
Posted on May 26, 2019
5 Related Answers
Anonymous
SOURCE: SHARP AQUOS LC-52D64U TV WITH NO POWER
I had one that was doing the same.   swapped out a back light inverter board... fixed it.  this doesn't mean that my fix will be your answer. to help find which one is of the 2 sides is bad..unplug power to the board one side at a time & half the lcd will fire up.  good luck
Posted on Apr 01, 2009
Anonymous
  • 117 Answers
SOURCE: My Sharp Aquos LC-52D64U shut off by itself, and
sounds like power supply/ohm supplies for repair in uk
Posted on Nov 23, 2009
bbl242003
Bruce lee
  • 1637 Answers
SOURCE: I have a sharp Aquos
Do you get any sound at all?
Solution
I had a similar problem. I had a 52" RCArear projection tv. It would do this when I initially turned on the television, but then after a few "on/off, on/off, on/off" cycles it would stay on. Eventually it started doing it more; until finally there was a spark and that was it. The tv was dead.The bloggers called it "the blinking green light of death" (because of green light on the panel).The power board is going out.ALSO holding down the Input and Menu buttons afterward will give you some diagnostic information via 2 sets of blinking indicator lights.
You may very well have issues with capacitors on this set being that it is or very similar to the V26 chassis. Since I have spare test lamps laying around, I would normally try that first. If the lamp still would not stay lit, I would then suspect the electrical chassis (capacitors). When I suspect the chassis, I can usually verify it by pulling it out and partially disassemble it and find blown capacitors
Posted on Jan 12, 2011
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: Sharp Aquos LC-42DH77E 42" LCD TV TV appears to
The PNL-POW (LCD panel Power) and the PS-ON will be 0V until the main board send out the signal to turn them on, it is working.
Do you get backlights?
Did you check the fuses on the Inverter board? You power supply is working.
This service manual may match your chassis:
http://elektrotanya.com/?q=showresult&megnev=Sharp&megnev2=LC-42DH77E&kategoria=&kat2=all
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Jun 01, 2011
Testimonial: "Helpful"
Chi Chu
  • 8457 Answers
SOURCE: What is the TV Tuner Signal Board part number for the Sharp Aquos LC-52d64U?
That the board which it have a square aluminun box at the edge of the board with a rounded bolt sticking out for inputs like ANT. input and AV inputs for like wires components inputs like multi colors like YRW,YRWGP holes for AV inputs also have HDMI hubs inputs for the high Def Pic.There are 6 HDMI inputs hubs for the tv Sharp Aquos LC-52d64U.Tvs Tuner board signal boards are also have to been known names to called as the tvs Main Logic boards and the tvs Mother boards also.U are fixing ur tv u must have to take it parts already.U can also compare the pictures between the tv Tuner signal board u are taking aparts out of the tv and the tv Tuner signal board you are buying they'll look axactly alike.The sticker of the serial numbers of the boards a few numbers in the begining on the tv Tuner signal boards should be the same also.
Posted on Dec 06, 2011
Sharp aquos won't turn on
if it was a new tv you can ask the supplier for check up it was covered with warranty.
Sep 22, 2012 | Sharp AQUOS LC-22SB28UT 22" LCD TV
Lc-52d64u Instruction_Manual
Grab a copy of your LC-52D64U manual here. I hope this helps!
Nov 09, 2011 | Sharp Televison & Video
We had a really bad storm yesterday with a lot of lightning. our power flickerd on and off a couple times but all of our electronics are plugged into surge protectors. everything in our house is working...
Few mins will not resetting tv and recovering power supply board from it protection modes that quick.Tries tv unplug,replug it back like about an hour later for tv resetting it back to the factory setting.The tv should get out it protections modes and might work again.If tv still have the same problems,than enough high currents got in the tv and kill ur tv power supply board.That the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.
Jun 30, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Aquos 42 won't turn on
Try unpluging it for 30 seconds and plug it back in. This is how some electronics are reset.
Dec 30, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp Aquos LC-52D64U Won't Turn On
I have fixed many sharp lcd tv's with a reset. If one appears to have no defects like bad capacitors, fried inverters, broken panel, ect. and the power light is flashing steady or not on at all a reset may help. There is a lot of bad information regarding the procedure though. The correct procedure is to unplug the tv, hold volume down and channel up at the same time and plug it in. Release those buttons then push the power button. Did it start? Great! I have no idea why so many seem to need this. If there truly is a problem this will only work temporarily or even momentarily but many will be fixed for good.
Apr 10, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Feb 26, 2009 | Sharp Aqous LC-26D5U Television
Televison & Video Logo
428 people viewed this question
Top Sharp Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
