Amp doesn't work
Check your fuses and see if they are blown. Check your in line fuse to your battery also. If this is not it try putting the amplifier in someone's existing and working system to see if it is your wiring. If this is the case redo try redoing your wire. If this does not work then you will need to send it in to the company that manufactures it for help. Please let me know if these work.
The 3E133 (or similar) Infra-Red Heater with correct voltage to the circuit board should produce a spark at the spark ignitor rod within a few seconds of having power applied. If it doesn't, one of the following could be the problem: (1. circuit board (ignition controller) is bad. (2. The gap between the spark ignitor rod and the middle rod (ground) is incorrect. It should be between 1/8" & 3/16". (3. There is not a good ground. This could be due to rust or a loose connection at any point between the equipment ground and the spark ignitor rod, including the ignitor mounting screws. (4. The spark ignitor rod or its orange wire is grounded, such as touching metal and thus "short circuiting" rather than allowing the spark ignitor rod to be 1/8" from "ground".
That's all I can think of that would cause NOTHING to happen.
