I need to know how to miter corners on a quilt using the Bernina Binding Foot.
IMHO, it is difficult to use a binder to miter corners. When using a binder to bind your project, it is easier to round the corners on your item. If your binding is bias cut, it will go right around the curve. Otherwise, a walking foot is good for attaching binding to a quilt (and you can miter the corners), but it does take more steps.
Check on youtube for a video
SOURCE: stitches
Usually a walking foot is for straight forward stitching only.It keeps the many layers from shifting for you. The "hand-look" quilting takes a couple stitches forward then one back. If you look close, you will see about every other stitch is thicker and stands out more.
SOURCE: I don't know how to use a Bernina foot I have
There are videos on the Bernina website on how to use the feet. #61 -#69 are all hemming feet. Look on this page of presser feet videos. Click the one that says #64.
http://www.berninausa.com/content-n401-sUS.html
hope this helps.
Rick
SOURCE: quilting
Janome now has a darning foot ie it looks like an embroidery foot with a spring designed for the 1600 models. It is metal with a ring where the needle goes down through it. I removed the plastic lens inside the ring and this seems to have resolved the problem.
I usually pull my threads to the top so I can see where they are and not getting tangled underneath.
There are several good groups on Yahoo groups which offer support for starting out on quilting
SOURCE: I need a Bernina 830 foot pedal. The machine is
You can fit any foot control providing you only have two leads coming from the control, you should be able to get a replacement Bernina control on www.sewingonline.co.uk/instructions
SOURCE: I have a singer 6202 sewing machine and I need to
You have to unscrew the presser foot, then attach the WF, using the same screw.
Make sure the lever on the WF rests on top of the needle bar clamp.
Some WF have a two prong lever and this fits around the needle clamp like a lobster claw.
I never could find a video for mitering corners with the binding foot!
