Here is a 10 day free trial of a software recovery program that can be burned to a disk. You would then boot from that disk with your external drive plugged in, and after it loads the software, tell it to find all available files. When you find your files, copy them to your regular hard drive and reformat the external. Copy the files back to your external drive. Hope that helps some.
Hi. You can hard reset your device by pressing the left and right upper softkeys at the same time, and while pressing them press the reset hole with the stylus. Don't forget to get a backup of all your data since a hard reset will erase your data. Hope this helps.
Try looking for a patch or updated driver for your sound system in your PC, integrated or a sound card that should be available at the manufacturers website(for mobo or integrated/external sound). After updating it should work, rather it has to because sp3 is better suited than SP2 and generally microsoft itself distributes the patches & updates. Alternatively you can visit driverguide.com, become a free member and let the Drive probe tell you which driver, including version, your PC will require to play audio/stero sounds........sodeep
Goto Settings-->Master Clear.
It will format all the handset and most important thing is you will lost all data inside the handset.
While Master Clear, it will ask for one code...then enter 1234 then for English select "REJECT" option whenever it asks for "ACCEPT". If you "ACCEPT" then the Arabic language wwill be installed.
Satya
