we cant guess your drive line, not now or ever.
so why ask. us?
my guess you mean the car drives in 1st gear but will not upshift,
and flares, in a false neutral.
wont and want is speed wrong 2 times, why?
Is car with TOD? torque on demand option, we cant see the dash board, we be like blind.
check fluild levels yet,
get the box serviced last decade, (a full flush and filter,) sure no.
check fuses, maybe car has TCM that cant up shift due to fuse blown.
and last did you scan it, if not why not
that be 3rd step after levels, fuses, then scan.
if the TCM cant see sensors, it cant upshift,
TCM is the tranny brain.
what does that mean, it has no clear meaning at all.
first is car a auto or stick (mines a stick)
stays in gear can mean many things,,,
1: A/t shift lever stuck in drive, you never said what gear,?
2: M/t sticks shift car, , the car moves in gear, with clutch held to floor.
i cant shift to neutral?
I cant shift to park.
I cant what? be clear. please
CarGurusJan 26, 2013 - the car starts up but i cant get it out of park the button on the shifterwont ... point the shift interlock will allow you to shift to neutral and other gears with ...That should expose your shift lock over ride button. .... Used Ford Taurus".
Feb 7, 2009 - Over the past week, it has been difficult to get the gear out of park. ... 97Ford Taurus gear shift stuck in park ... LOCK, then remove the key. 2.
? 3:49
https://www.youtube.com/watch?v=ZdDsfNrabsM
Mar 21, 2014 - Uploaded by BleepinJeep
Only problem is if it fails, you cant get your car out of park. ...Those interlocks seem like they might be a solenoid that slides alock pin out so that you can move the lever freely. .... Someone told me it was possibly the Passing gear cable ? ... Ford TaurusWon't Shift Out Of Park, Brake Lights Don't Work With ...
the 5speed box.
sure, but is the clutch bad or the shift lever. bad.
so can you start car in gear with clutch depressed.?
yes, no. (or jerks car body)(
"cant"
does that mean tranny is stuck in netural/
or does it mean the clutch drags and the shifter will not shift in any gear? or grinds>
or cant means the clutch slips in all 5 gears and Reverse.?
or can mean parts 27 bad.
you have a definate concern inside the transmission your gears are marred badly the gears 2-5 are synchrnized and helical style for smooth shifting 1st and reverse are spur cut so you cant accidentally shift into these gears while driving i would look for a good used transmission
ur gear shift has a little plastic bar on gear shift and it has crack on the side u cant see have it changed out and both of ur problems will be solved at same time.
