I brought second hand smeg fab 32 and i do not know what the 2 switches just inside top of the fridge part
SOURCE: Smeg Fridge light
What you need to locate is the door switch mechanism for the fridge. These are normally located towards the top of the door and protrude so that when the door closes the switch is pushed in. To find out if you have a problem with the switch just press it when the door is open and the light should go off. The switch itself can appear in various forms either as a protruding rod or a curved plate which pushes upwards against the door side when it closes. If I could draw in this section it could be better explained. But if you look around the inside of the fridge on the side away from the door hinge then you should find something you can push. Sorry to be this vague. If you do need a replacement switch they are normally quite simple to change depending on where they are located, most are two screws, or just a push in type. Hope this has been of some help.
SOURCE: Smeg Fab 32 door problem
The Door on my SMEG Retro Fridge keeps opening on its own accord ? There's nothing inside poushing up against it so why does this keep happening ?
SOURCE: How do I remove Smeg FAB 28 Fridge door,as I have
remove the top of the fridge by removing the two screws on the back of the top and sliding the top to the back. that gives you access to the doorhinges. remove the three screews of the lower hinge, which allows you to remove the door from the upper hinge too. (sorry, non native speaker)
