SOURCE: Fridge not cold enough and build up of ice at back of fridge
We had the same problem and were told that gas was not circulating properly. We had it topped up, but it broke a week later. It had to be scrapped.
SOURCE: SMEG FAB28
Check the seal is tight all around the door - clean it to within an inch of it's life.
Then make sure the drain hole (inside at the bottom of the fridge) isn't blocked (a long handled screwdriver with kitchen roll wrapped around it will suffice). You can tell the drain hole is blocked as it's characterised by the door being difficult to open in quick succession (plus - you can see it's blocked).
Next, defrost the fridge completely: Power off, open door on freezer compartment & fridge and mop up the damp. When totally dry, turn back on (without food - let it cool properly before putting food back).
I had the condensation problem and it's now sorted. Not sure which cause was responsible, but the 'solution' is worth a try.
David W.
SOURCE: Smeg fridge which keeps freezing and doesnt auto defrost
the defrost timer or the defrost heater needs replaced
Testimonial: "Thanks very much!"
SOURCE: Smeg Fab 32 door problem
The Door on my SMEG Retro Fridge keeps opening on its own accord ? There's nothing inside poushing up against it so why does this keep happening ?
