Refer to the manual page below - note the last 2 items
If you take the camera and the card to a sales outlet the assistants are usually helpful
Inserting an SD Memory Card(Optional)
All images and video clips taken by the camera can be stored in an SD (Secure
Digital) Memory Card. Even if the camera's power is OFF, the images saved in the
SD Memory Card are not erased. An SD Memory Card can be repeatedly read and
written. You may also expand the memory capacity up to 512MB so that you can
store additional images and video clips.
1. Make sure the camera is off.
2. Slide the battery/SD Memory Card cover in the direction of the [OPEN] arrow.
3. Insert an SD Memory Card :
The front side of the memory card (printed
arrow) should face towards the front side
of the camera.
If the card cannot be inserted, check the
orientation.
4. Close the battery/SD Memory Card cover.
To remove the SD Memory Card, make sure
the camera is off. Open the battery/SD Memory Card card cover. Press
lightly on the edge of the memory card and it will eject.
Note:
If the camera is powered-on without the card, the "NO CARD" message appears on
the LCD monitor.
To prevent valuable data from being accidentally
erased from an SD Memory Card you can slide the
write-protected tab (on the side of the SD Memory
Card) to "LOCK".
To save, edit or erase data on an SD Memory Card,
you must unlock the card.
MultiMedia Card (MMC) can not be used.
You need to format an SD Memory Card before using it in this camera
You can save videos to SD card by following these steps.
1.Purchase a micro SD card adapter, which will allow you to insert the smaller card into SD card readers and computers. Many of the newer phones come with the adapter.
2. Insert the micro SD card and adapter into the card reader. Make sure your computer recognizes by accessing "My Computer" on your PC and clicking on the drive letter associated with your card reader.
3.Drag and drop videos or other data to the drive containing the micro SD card. Or right-click on anything you want to save, and then click on "Save As." Save the file to the correct drive.
4.Pop the memory card into your digital phone. Access it using the "Tools" menu on the phone.
Im assuming the monitor worked OK until now. The two things I can think of is, First is the cable from the monitor to the computer is either not connected tight either on the monitor side or the computer. The second thing I can think of is a bad video card. I think the monitor is ok because your getting the power save mode on the screen.
I hope this helps you out, if it does please leave me some positive feedback.
Make sure that the video camcorder was not turned off immediately after recording before the images are saved in memory. Also be sure that your memory card is properly inserted in your camera.
Yes, a bad video card could prevent the computer from starting at all. Your monitor is going into power save mode because the computer isn't sending a video signal. This could be due to many things, power supply, memory, video card, processor. Try blowing all the dust from it and reseating all the components.
Do you have a memory card? Please use a memory card in the camera, make sure the camera is set to use the memory card and not internal memory, the internal memory may be emptyed on power off so make sure the pictures are saved to storage card where they wont be effected.
i think you have broken or bended any of the pin inside the card slot, and that is creating problem. Try looking in the card slot you may find any of the connector pin broken or bended. Try straighten the pin cautiously and may your machine start working .
