LG Flatron L1710S  17" LCD Monitor
Problems with LG Flatron L1710S 17" LCD Monitor?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
LG Flatron L1710S (Silver) 17" LCD...
Troubleshooting and Support
Solved Problems for LG Flatron L1710S  17" LCD Monitor RSS Feed
Click here to get instant support from our best Experts!
View More Results for LG Flatron L1710S 17" LCD Monitor
Questions and Unsolved Support Problems
Unsolved Problems for LG Flatron L1710S  17" LCD Monitor RSS Feed
Answer
In my tft monitor wave lines comming. may i know what the problem?
Answer
my lg flatron l1710s flashes on and then the picture goes out and thats it but the power light stays... (More)
Answer
My 22'' Lg flatron w2234s was fine until this afternoon I played warcraft, it came up 4:3 in a box... (More)
Answer
my monitor after 15 times pressing the power button turns on sometimes used to go on quick but now... (More)
Answer
when starting up my pc monitor shows very brightish black n gray appearance after half an hr it... (More)
Find a Manual
LG Flatron L1710S 17" LCD Monitor Manuals & Guides
WikiManual
(Post a New Chapter)
How to Fix a Scratch on an LCD Screen
Use Vaseline petroleum jelly to fill a scratch on an LCD screen. This works because the optical density more closely matches the LCD face than air.... by wikihow
How to Fix a Stuck Pixel on an LCD Monitor
If your LCD screen has a stuck or dead pixel (a point on the screen that is always lit or always dark), it is usually due to a transistor malfunction... by wikihow
How to Improve Image Quality on an LCD Monitor
One method to improve the display on an LCD monitor is to use a DVI connector on a DVI capable video card. This is due to the fact that LCD monitors... by wikihow
Upload Manuals
Tips & How To Guides for the LG Flatron L1710S 17" LCD Monitor
Earn cash by writing Tips & How-To's.
It's easy!  (Learn more)
How to remove the case on LCD monitors
This tip will explain how to open the case on most LCD monitors. Most monitors will eventually have a problem with the power supply and need... written by buddymc
USE YOUR LCD TV AS A COMPUTER MONITOR BY WAY OF HDMI.
To use your LCD TV as a monitor. look for a HDMI output on the computer and the TV. If you dont have a HDMI output on the computer, you will need to... written by tbrat44
Monitor led is blinking or steady, but the display does not come up
The monitor is probably on protection. To start unplug monitor from power and from computer and test computer with different monitor to find out if... written by ginko
Hannspree, I-inc, Hannsg
Don't buy and products from this company they get cheap parts from companies going out of business. They are built to break down as soon as the... written by worthy42
Help FixYa, Help you and help others. Share your User maunals and...
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for... written by stoneheaded
Determine if you are having problems with your monitor or video card in...
Many people have problems determining if their monitor is bad or their video card is bad. One good way to test this is by swapping out your monitor... written by BobbyR1234
if there is discoloration then follow this
The discoloration problem is due to the near by magnetic field appliances like speakers which are very near to monitors ... so what you have to do is... written by dileep007
LG L1719 17" monitor
I'd like to know how to disconnect the stand from this model monitor, it's shows u how to put it in place but not how to remove it i even checked on... written by Kimmi2069
I need help with
near zipcode:
Please enter your zipcode
Search
Top Repair Providers for LG Flatron L1710S 17" LCD Monitor
Nationwide | 5138743306 | Website
We fix and repair laptop motherboard no video, no pow... Read More
Featured Listing
Nationwide | (952)890-7770 | Website
Zkarlo.com provides discount and used laptop parts for... Read More
Featured Listing
Nationwide | 877-934-6198 | Website
Send your laptop to us and we will diagnose the pro... Read More
Featured Listing
Nationwide | 8005882188
Featured Listing
Nationwide | 8664878724
Featured Listing
Nationwide | 8004130133 | Website
We offer computer consulting services, hardware and... Read More
Nationwide | 407-284-1943 | Website
Affordable Laptop and Desktop Repair. We spe... Read More
Nationwide | 254-718-4042 | Website
we Service most consumer electronics. cb's twoway ham... Read More
Nationwide | 601-918-0222
I will connect to your Computer and repair the tro... Read More
Nationwide | 4695217517 | Website
We repair LCD Monitors and TV's. We also carry a lar... Read More
Ratings for the
Find a Warranty
Specifications for LG Flatron L1710S 17" LCD Monitor
Key Features
Aspect Ratio
5:4 (Regular)
Size
17"
Color Depth
24-bit (16.7M colors)
Contrast Ratio
550:1
Brightness
250 cd/m
Max. Resolution
1280 x 1024
Dot Pitch
0.26 mm
Monitor Type
Flat Panel LCD TFT (Active Matrix)
Response Time
16 ms
Viewable Picture Size
17 in.
Technical Features
Form Factor
Desktop
Regulatory Approval
CE · UL · cUL · FCC Class B · TUV-GS · ISO 13406-2 (Pixel defect guidelines) · Energy star · TCO-99 · SEMKO · MPR-II · GOST-R
Synchronization Range - Horizontal
30 - 83 kHz
Max. Viewing Angle - Horizontal
160
Max. Viewing Angle - Vertical
140
Native (Recommended) Resolution
1280 x 1024
Resolutions supported
1280 x 1024 · 800 x 600 · 640 x 480 · 1024 x 768 · 832 x 624 · 1152 x 870 · 720 x 400 · 640 x 350 · 1152 x 900
Synchronization Range - Vertical
56 - 75 Hz
Dimensions
Depth
8.79 in.
Height
16.59 in.
Width
14.58 in.
Weight
14.55 lb.
Warranty
Warranty
3 Years
LG Contact Information
Main support number1-800-243-0000
Email supportcustomerservice@lge.com
Describe your problem:
Top Monitor Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
