I have just had a mechanic out. I have the same problem. It turns out that the front panel is gone on it. I had it in storage, and it got damp. It is not worth getting fixed, as it will cost about 300 euro!!
Jun 26, 2011 - Uploaded by XR600RQJ
Washing machine Indesit starts to flash for longer and longer ...How do you unlock the door when the power is off?? every time i turn it ... My washing maschine ( Indesit WITXL 129 ) had the same problem - 6 from 9 LED lights ..
Hi The light is
flashing due to the door lock error. The door lock is activated as the machine
experienced an error or was stopped in middle of a cycle. Or the door was being
pulled while the machine was running a cycle. Try unplugging your washer and
restart the washer to check if you are still getting the same blinking light.
If error is still not resolved then start the rinse/spin cycle & stop
the cycle, now press and hold the cancel button for 5-10 seconds. However,
if you are still not able to get the door open then you'll need to open the
door manually by disassembling the washer. Hope this helps... Please post back
for any further assistance. Daniel
button selection : To select an option press the button and you will see a light come on above the button. Press again to cancel and the light will go out. You cannot alter the options once the machine is running. Note : remember to cancel buttons after use!
As you look at the machine
Left hand button... Rinse Hold.. use this option to Help reduce creasing of delicate or synthetic fabrics by holding clothes in the final rinse water. The rinse hold light will flash to indicate that the programme is holding final rinse water. Complete the final spin by pressing the Rinse Hold button when light is flashing.
This is not available with Wool or Spin only programmes.
Middle Button.... Energy Save... use this option to save money and time on lightly soiled loads. This is not available with the Quick Wash, Rinse and Spin, or Spin Only programmes.
Right Hand Button .... Super Rinse... use this option for Large Wash loads and items for young children or people with sensitive skin. This option increases the water level for the first two rinses. This is not available with Cold Wash, Rinse and Spin or Spin Only programmes.
Copied from my Hotpoint FEW12 user instruction sheet.
Hope it helps.
The lights are set off by the balance sensors.And if your balance sensors are stopping it from spinning than you first have to make sure the washer is level.You could have bad Shocks and a bad electronic control board,.
check your pump for any blockages it may not be pumping out fast enough the tomer only gives the pump a certain amount of time to pump all the water out if has got some blockage than clean out and this should sort the problem out always check pockets if this is no help let me know and ill let u know what else it could be m8
try pushing the door closed again, i have a problem with my machine that when i put a load on it starts then stops the light starts flashing then i firmly push the door (at the handle side) and it starts to work again, it might help!
on/off light flashes as well as the rinse/hold light
