Question about Kenmore 24032\24036 Top Load Washer
Indesit washing machine
Power indicator and rpm indicator flashes
Posted by vasilakis dennis on
Claude Kayser
    Top Expert:
  • Kenmore Master
  • 9,098 Answers
Indesit Washing Machine lWB5113 Flashing Lights(Faulty ...
? 3:34
www.youtube.com/watch?v=-lnfePzPwTQ
Jul 29, 2012 - Uploaded by porracaralho caralho
Indesit Washing Machine lWB5113 Flashing Lights(Faulty).mp4 .... older model- stopped in rinse cycle/flashing power and rapid wash lights- ...
How to repair Indesit washing machine that is Flashing ...
? 0:43
www.youtube.com/watch?v=Q9Yq2Cz8UFE
Jun 26, 2011 - Uploaded by XR600RQJ
Washing machine Indesit starts to flash for longer and longer ...How do you unlock the door when the power is off?? every time i turn it ... My washing maschine ( Indesit WITXL 129 ) had the same problem - 6 from 9 LED lights ..
Posted on Oct 14, 2015
See:
? 3:34
Jul 29, 2012 - Uploaded by porracaralho caralho Indesit Washing Machine lWB5113 Flashing Lights(Faulty).mp4 .... older model- stopped in rinse cycle/flashing power and rapid wash lights- ...
? 0:43
Engine surges in first gear around 6000 rpm, producing violent excelleration and then an abrupt pause over and over again until I shift into 2nd. this usually will not occure until about 2 hours of riding,...
If you are running ANY engine to 6000 rpm in first gear, you are thrashing the hell out of it and that is a problem/catastrophe waiting to happen. Stop hammering the engine and shift out of first at around 2000 rpm at the most. You might spin the crankshaft bearings or over torque the crankshaft - that is if you don't break the connecting rod and throw the piston into the valves and destroy the cylinder head. 6000 RPM! That is just crazy.
Treadmill speed up button doesn't work. Everything else works.
RPM SENSOR:
indicates input signal from the RPM sensor to the MCB.If the LED, is not flashing, please review the following:
1) Sensor disconnected from the MCB.
2)RPM SENSOR misaligned.
3)RPM sensor faulty.
e.cuadra
Hi Guyz I have a 1999 1.4i Polo Playa (South Africa) Which is currently firing at 25 deg btdc @ 1000 rpm. if i advance or ******, it gets very rough. What is the correct ignition firing position @ what...
correct ignition timing should be at 10 degrees btdc at idle ( 850 rpms )
use a timing light connected to no 1 piston ht lead to set the timingby adjusting the distributor to get the light to flash on the timing mark
the vacuum hose is probably to increase idle speed when then ac is on and the surginging indicates a leak in a diaphragm
My craftsman door opener went up half way and stopped. Light on u nit was not on and indicator light flashed 5 times, the repeats 5 flashes. billybob
The code for that light flashing 5 times is 'motor overheated or RPM sensor failure'. The RPM sensor is a small printed circuit board just in front of the motor. Release the door from the opener and operate by hand. It should raise easily and should stay put when it is about waist high.
Doesn't spin & Power light flashes red to green
This situation indicates a problem with the built-in self tests. Most likely a power supply failure. I don't believe it is economically feasible to replace the power supply. If it is still under warranty, I'd go through the procedure to get it repaired/replaced. Otherwise, you'll need to replace the unit.
1helpful
The service engine light is flashing, loss of power through rpm range, and has no DTC codes, flashes untill I come to a stop.
If the Service engine light is flashing, that indicates the presence of a missfire condition, also know as pinging, or preignition. If the light is flashing you could potentially be harming the engine even further by driving it any distance at all!
1helpful
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link - http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF55XS955&content_id=68&category_id=11&problem_id=52
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Craftsman 1/2 horsepower not working
Five flashes indicates possible RPM sensor failure. First try unplugging opener for five minutes and plug back in. If it still does not work replace RPM sensor.
Kenmore 24032\24036 Top Load Washer Logo
Michael Thomas
Michael Thomas
Paul Carew
Lawrence Oravetz
