I am getting an error and it is unable to initialize at start up. The error is as follows: 0x841270671:hc. can someone help solve
SOURCE: hp psc 1610 all in one printer
prani, i worked on my printer for almost an hour, you solved it in one minute,thank you.
SOURCE: Connecting 2 PCs to the HP PSC 1610 Printer at the same time
Hey,
This usb printer can only be connected to one pc at a time, you could use a USB SWITCH to connect both computers to the switch and printer into the other end, so with the press of a button you could connect the printer from port 1 (pc1) to port 2 (pc2)
Click here
Thanks,
Ekse
SOURCE: printer is not printing
Normal 0
Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came withthe printer. When the software program asks you to connect theprinter to the USB port, do so and it should again work properly.
Hope this helps. Bud
SOURCE: can u use the scanner on a hp pcs 1610 all in one
Hi, the answer is no you cannot, the printer will only work if both cartridges (black and color) are installed, if you install just one the check print cartridge light will flash.
Hope this helps
Muzzi_123
SOURCE: Need to install software for
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=390315
The above link will furnish your drivers, & support simply enter your Operating System, and download and install, remember to install as Administrator.
