After recording, when I go to playback the tape the screen stays blue and just shows the tape diagram.
Tape plays no problem but no picture or sound.
This also happens with tapes that I know has data on them.
The playback head is dirty. Insert a brand new tape into the drive and perform a record, through the entire tape until it reaches the end. Then play a pre-recorded tape.
The playback head is probably dirty and cannot show the picture - the screen is blue. Run a blank tape in the tape drive and execute a record all the way through the tape. Then play back a pre-recorded tape to verify it plays back ok.
Follow this procedure to troubleshoot if a blue screen is displayed when attempting to playback video from the camcorder.
Stop the tape.
Ensure the tape has been rewound to the beginning of the video recording.
Play the tape.
If the issue is not resolved, stop the tape and remove it from the camcorder.
Clean the video heads of the camcorder using a dry head cleaning cassette.IMPORTANT: Follow the instructions for use provided with the head cleaning cassette. It may be necessary to use the head cleaning cassette more than once per session.
Reinsert the tape into the camcorder.
Play the tape.
Insert a different tape with video footage into the camcorder.
You can see an image in a camcorder viewfinder any time the camera's actually on in record mode, whether or not the camcorder is actually recording. So that's no guarantee.
Assuming the obvious (you have the right kind of tapes, they're not in write-protect mode, you rewind before playing, etc). I recommend that you borrow a tape of the same kind from someone else and check it on playback in your camcorder. This should lead you know understand if you have a playback problem or a recording problem.
a sony cleaning cassette may clear the gunk from
your friend ' s possibly ? bad tapes ( do not
rewind it - or the gunk will be redeposited ) ;
if still no video , get an estimate to have your
heads and guides cleaned . . . professionally ;
