20 Most Recent Canon FS200 Flash Media Camcorder Questions & Answers
I cannot tell you what the error is, but perhaps I can give you some tips on how to solve the problem. First, try to read the SD card on your computer. Is it formatted? if not, format to FAT 32. Are there any file structures? If so, erase and format the SD card to FAT 32.
If these activities do not work, then try with another SD or SDHC card (type 10 if possible) and see if the error is replicated.
From there, recommend contacting Canon customer support for assistance.
Canon FS200 ... | Answered on Apr 20, 2015
Hi , it is also located on the box , it came in on the bar code , i had problems reagistaring it as well off the camera , the box has a couple extra zero's in it i believe. good luck
Canon FS200 ... | Answered on Aug 12, 2014
You will need a 3.5 to rca ( RED,WHITE,YELLOW) , then select the input source video, 1,2 or 3 pending what tv you have , if you have no rca inputs and just a screw in cable input , you can buy a converter for around 20 bucks , good luck
go into the settings and switch to external mic and dont use the mic. or if you have an on off switch on the mic switch to off , its cumbersome but works. I have forgot to plug it in all the way and that too works gives you video no sound. you dont need a new camera , good luck
Canon FS200 ... | Answered on Jun 22, 2014
I know it's probaly pointless in 2014 to post this, but all you need to do is rename the video file so that it has an ".AVI" extension (Google "show extension names on Mac" if you need to). The ".PGI" file is used only by the camera, and is not used for any type of decoding on other devices (meaning you don't need it, and should just delete them).
Canon FS200 ... | Answered on Feb 07, 2014
instead you can use this utility (see download below). If you have a card reader in your PC then this utility makes live even easier....
http://users.telenet.be/truyens/
Canon FS200 ... | Answered on Dec 20, 2013
You definitely have anti-virus installed in your system (Computer), As a result system prompted for SCAN & fix due to possible virus or worms found in your device (Canon), At the moment you click that "Do you want scan & fix canon", the system have cleared/deleted the virus or worm infected file, In the result you are unable to find the video files again or If it is there it will not run. I would recommend you to formate your Memory Card and then use it. There is no way to recover that video again.
Hope this will help,
Thanks..!!
Canon FS200 ... | Answered on Feb 04, 2013
http://www.usa.canon.com/cusa/support/consumer/camcorders/flash_memory_camcorders/fs200#DriversAndSoftware
Go here ...is teh official Canon support site ..select the operation system you use and download the original software again ...even if it will ask for the serial it will have to accept the one from your camera ..but it will not ..
another thing that you may do if this will give you trouble ...is to use the direct card to download the video s..Being a flash memory card ...all you need is a card reader that fits with the card ...and the computer will see the card ann all that it is on it directly ..from the card ...and you will be able to copy them just like from a memory stick ..
Canon FS200 ... | Answered on Jan 03, 2013
Any stereo microphone could work, not specific
Canon FS200 ... | Answered on Aug 22, 2012
Do you have iMovie? On mine, with any camcorder I've had, when I have iMovie running and plug the camcorder in it automatically changes to the Record mode. Click on the forward button and it will start the camcorder. Press the Record button when you get to the part you want to record. You can then edit the beginning or end of the section to use the portion(s) you want. The software controls the camcorder to go frontwards or backwards. Works very slick. Not sure what to suggest if you don't use iMovie.
Canon FS200 ... | Answered on Jul 22, 2012
On the bottom of the camers on the battery door there is a sticker with some letters and numbers. The serial number is the first 12 numbers that are listed on the first 3 rows. No letters at all.
Canon FS200 ... | Answered on Apr 16, 2012
Canon FS200  Flash Media Camcorder Logo
115 questions posted
Top Canon Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
View Most Popular
FS Canon
  • FS Canon
Most Popular Question
download pixela transfer utility
  • Video Cameras
