20 Most Recent
Sony DCR-HC30E MiniDV Camcorder Questions & Answers
Blue screen on lcd screen
The playback head is probably dirty and cannot show the picture - the screen is blue. Run a blank tape in the tape drive and execute a record all the way through the tape. Then play back a pre-recorded tape to verify it plays back ok.
How play the recorded video?
The controls for playback are on the touch screen once the camera is switched from record mode to playback mode, if the camcorder isnt playing back then you might ned to have the unit serviced, could be a bad video head assy. I hope this helps.
Can't see anything in LCS display
problem on ur lcd fpc that connecting camera to lcd that u want to chaing .if u cant chaing try to contact me my no.00971503853766 in u.a.e i have a service center
Help me plause
If you are using Win XP or later, you dont need any driver.
Check if cam has the firewire port. If so, you can get a 4 pin firewire cable and connect to the PC.
Switch on the Cam.
Open Windows Movie Maker and import video from device.
4 pin firewire would look like this:
http://www.pcab.co.uk/ebay/firewire%204%20to%204.jpg
Cannot see enything looks like the cover is
BAD CCD !
see the link for free repairs from Sony dont worry if u
are out of warranty and not on list just call them PLS RATE ME FIXYA
for help
http://www.imaging-resource.com/badccds.html
For support just call SONY Europe
http://support.sony-europe.com/dime/camcorders/dv/dv.aspx?site=odw_en_GB&m=DCR-HC30E
UNABLE TO DETECT VIDEO CAMERA
You need to use firewire cable. USB wont work.
Get a 4 pin firewire cable and connect to the PC.
Switch on the Cam.
Hello, i have a problem with my handycam Sony
Hi, Check if it has the firewire port. If so, you can get a 4 pin firewire cable and connect to the PC and record/ download the videos using Windows Movie Maker.
You can use the Movie maker to burn it to the Disk
Hc30e camcorder
You need not have a CD.
Check if the cam has the firewire port. If so, you can get a 4 pin firewire cable and connect to the PC.
Switch on the Cam.
