SOURCE: need to replace the control board printed circuit
Try these two websites, they have chat assistance 24/7 and I am sure they should be able to answer your questions and help get the part you need.
Good Luck,
I hope this helps
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
SOURCE: Frigidaire Oven Error F1, what caused it?
Hello - From my research part number: 318184400 (clock) seems that it has not yet been updated and still the same part number for the MSRP: $163.04. Part can be purchase directly from the manufacturer or a part distributor in your area (part could possibly be different with them). Typically error code F10 could indicate a variety of issues. The range could possibly have a runaway temp (higher than normal temps), shorted keypad, faulty EOC (Electronic Oven Control) or, display wire harness missing/not connected. Usually, this code means to replace the EOC. You may be able to reset the range by disconnecting the power to the unit for up ten minutes. Usually this will clear most false error codes. You can disconnect power by either unplugging the unit or flipping the circuit breaker off and back on. If resetting the unit proves to be ineffective, I would recommend contacting a professional to move forward accurately.
