Dryers Logo
Posted on Jul 23, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We've got a noisy Maytag gas dryer and it has been suggested it needs brake shoes on the front and rollers on the back of the drum. Is anyone near enough to Oberon to assist us please?
Dan Webster
Level 3:
  • Maytag Master 8,221 Answers
  • Posted on Jul 23, 2012
Dan Webster
Maytag Master
Level 3:
Answers
8221
Questions
5
Helped
2381134
Points
25840
To access the front you remove 2 screws at the base of the front and remove the front panel, newer models you pop the top first. Not all maytags are exactly the same. The front of the drum rides on plastic glides and the rear of the dryer rides on rollers. I made a few maytag dryer home videos HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
1 Related Answer
ginko
Ginko
  • 19396 Answers
  • Posted on May 06, 2009
SOURCE: Maytag gas Dryer is Noisy
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the drum.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
If dryer is not cooling, check that the noise is not coming from the ventilation fan.
Rollers and belt tensioner can also make noise.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Have a Maytag Bravos XL MEDB9504WO that works, but very noisy. Bought a pulley that sits on top of
Sounds like you need new drum rollers, so you need to disassemble the front of the machine and remove drum replace all drum rollers and idler pulley also check blower for damage.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gary_58e9c3508cafe590
3answers
Model 8600 , drum makes loud noise, not a squeak
HI,
If your dryer is noisy, check these:
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
My ge gas dryer squeeks its *** off
Helo there and welcome to fixya
This is a fairly common problem with these dryers
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them. Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn. Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
Dec 15, 2011 • Dryers
1helpful
The dryer is making a knocking sound when running. The sound has increased lately. What may be the cause of the noise?
Hello there and thank you for choosing fixya
5helpful
When I turn on the dryer it squeeks very loud for a minute or tow. What do I need to replace to fix this problem???
2helpful
Maytag MDE5500AYW 220V Electric Dryer. Makes a
Your dryers uses rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley your dryer has a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Rear drum bearing. There are videos of the testing and replacing of these parts at www.appliancehelponline.com/servicemanual.html this will walk you thru the troubleshooting and replacement of these parts Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. This brings us to the last problem could be the blower wheel, which is usually plastic, may wear out over time.To check this grab the wheel and see if theres any play . But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you need to replace it. If you need diagrams or illustrations of your specific model you can also enter your model # there.
I have a maytag performa dryer model #pdet920ayw and when i turn it on it squeels.
Below are some links, courtesy of www.repairclinic.com, that will assist you in diagnosing/repair of your dryer. You may have to enter your model number in the search box to access some of the information.
Below is a parts breakdown/disassembly procedure for your dryer.
http://www.repairclinic.com/Dryer-Electric-Maytag-Style-Appliance-Diagram
The most common cause of a squeal is the drum roller, of which there are 2. It is usually a good idea to replace both rollers, roller shafts and drum belt at the same time, as they have a tendency to wear at the same rate. You must also use the proper lubricant on the roller shafts, (Syl-Glide), or you will have a recurrence of the squeal.
1. Drum Roller Image
http://www.repairclinic.com/SSPartDetail.aspx?s=t-pdet920ayw-%3d%3di966673&PartID=966673
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
You can also obtain more appliance information at my website, www.homemanagement.services.officelive.com
Model no. LDE8506ACE has a noise when running seems like maybe drum rollers or belt. how do I get to drum?
This link is provided by www.repairclinic.com and shows parts breakdown/disassembly procedures, etc.
A faulty blower could also cause a noise during operation and as the motor slow rpms on stopping.
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
