Maytag Atlantic dryer (model #MDG7600AWW) just had new thermostat replaced and duct/vent cleaned but...
(More)
Maytag Atlantic dryer (model #MDG7600AWW) just had new thermostat replaced and duct/vent cleaned but now will not heat up. I did have the window open on the day it stopped heating - could the wind have done something? Does this dryer have a pilot light that could have blown out? Thanks for your help!
My Maytag LDG8604AAE clothes Dryer doesn't heat. The ignitor lights, then there is flame for about 5...
(More)
My Maytag LDG8604AAE clothes Dryer doesn't heat. The ignitor lights, then there is flame for about 5 seconds. Then the flame shuts off but the tumbler keeps turning
This advice is for all ELECTRIC Dryers that have a "No Heat" problem. Symptom: Dryer turns on, drum spins, but you have no heat. Any of the...
written by jsrock516
This advice is for dryer belt replacement on most Kenmore Elite and Whirlpool Duet model dryers. If in doubt, please provide me with a complete model...
Dryers come with a wire or metal strap connecting the center "neutral" terminal to the frame of the dryer. When using a four wire power...
written by MNTECH
To reduce the suction draft and drying time your drier and save some cash, remove the lint catcher and take it to the sink. Run water into it, if...
written by DRRXR
1. Disconnect electrical power to dryer. 2. Remove the lid. 3.On the front panel there is a circuit board (moisture sensor control board) with a six...
written by gregorymholt
This
advice is on how to correctly install an ELECTRIC DRYER or ELECTRIC RANGE
220-240VAC power cord (US Standards).
3-Prong or 4-Prong ?...
If your dryer vent hasn't been cleaned in the past year or two, it probably needs it. There may even be a bird's nest in there. How do you clean...
by wikihow
Modern appliances come with separate ground and neutral wires. Generally, this setup is safer, because the current-carrying neutral is not connected...
by wikihow
Most of the problems in a dryer are caused by poor air circulation inside of the dryer. The dryer will suck air from the outside, pass it through the...
by wikihow
Do you hear clanking noises coming from inside of your dryer tumbler? It may be time to replace the dryer baffles. Here is how to check and go about...
by wikihow
Tips on how to prevent the dryer cord and terminal block from burning out.
Steps
1. The cause of the dryer cord wires and the terminal block for...
by wikihow
Welcome to Action Appliance Repair. We have bee... Read More
Welcome to Action Appliance Repair. We have been serving the greater Hartford and Springfield area for over 40 years. We are dedicated to working around your busy schedule. Please call now to receive the $25.00 discount coupon available. We are family owned since 1961. Call now for your free ph
Washer and Dryer repair specialists.
Why hire som... Read More
Why hire someone else to fix your appliance when you can do it yourself? And we can help!
Download a step by step tutorial loaded with pics at www.shop.washermd.com
Our focus will always be to provide top-notch qua... Read More
Our focus will always be to provide top-notch quality service and customer satisfaction of repair services to our customers and partners on Warranty/non-Warranty Dimplex heaters, TV & Electronics, HVAC, Electricity, Home & Industrial Appliances, Sports & Exercise Equipment, Treadmills, Spas & Saunas, Office & Computer Peripherals.
