I need to edit a read-only batch file on the flash rom on the 6846. I can edit other files, but not this batch file. I can edit it in the RamDrive, but lose my changes any time we have to do a cold-boot. Of course there is no 'attrib' command, but is there some other way to accomplish this?
You will need to extract the files from the terminal to be able to edit them normally and then rebuild the hex file to reload on to it.
There are two commands that you may want to try on the terminal but i doubt you will be able to modify the file.
flshctl /w will enable you to write on the flash.
flshctl /ro will disable the write option.
