I have had an issue with my ice for the past few weeks. I replace the water filter in my refridgerator and just recently had my ice maker replaced completely. Neither has helped; could this be an issue of the water supply line? If so, how could I go about replacing that?
The ice maker model type is GCD-23.
SOURCE: Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
SOURCE: No water to the ice maker
Yeah, the valve is definitely not turned on. Just turn the valve and you should be good to go...
SOURCE: Ice maker only produces crushed ice
not really a reset button but htere is a solenoid that controls the type of ice coming out of dispenser. with the ice bucket in place give a look at it from underneath and find the brass rod spanning from front to back of bucket. that rod hooks into a solenoid catch that when activated lifts the rod up and down for crushed/ or cubed ice.. after locating the "hole" in which the rod enters you should also see a corresponding plastic ring that would catch the rod upn activating stich and pull/up and down.. Ill assume that the "catch ring" is tuck in the up positon , might only be frozen up in which case you can hit it with a hair dryer to melt it, its also possible that the \solenoid had melted it self in the up position in which case you need to replace it.. to check this theory you can hook the brass rod into the ring assy in which case youll only dispense cubed no crushed
SOURCE: Ice maker not getting water from water valve
CAN YOU HEAR THE WTR VALVE ACTIVATE OR TRY TO SEND WTR TO ICE MAKER HAVE YOU CHECK THE FILL TUBE INSIDE FREZZER WHEN THEY FREEZE INSIDE TUBE WTR WONT BE DISPENCE INTO MOLD
SOURCE: water dispenser and ice maker not working
Hi!! tony , yes you have a bad water valve its located on the bottom back of your frig..Replace your water valve..Good luck..
