Make sure all your computers are using the "Workgroup" and that all the workgroup names are the same.
Go to "My Computer" - right click and select "Properties". When the windows open select the "Computer Name" tab. Check the name for "Workgroup" - it is normally defaulted to "WORKGROUP". Make sure all you computers have the same name. Then, you can select which directories you want to share on your computer, right click in "Windows Explorer" and select "Share". It will ask you what name you want to use. "Select anything you want. On other computers, you should then bwe able to connect to that directory by using <computer name>/<directory name>.
this is just the basics - it can get very difficult if you need to interface between different versions of windows or if one of your computers is not in a workgroup. Good Luck.
