Click start click on my computer you should see your memory card
right click then select format
another way is to control panel administrive tools computer management disk management right click on your memory card or it might be listed as a mass storage device
select format
you will see what its formatted in
hope this helps
SOURCE: 8gb PNY USB2 flash drive refuses FORMAT Can it
use un lockaer it wil shows were the problem is .........................
SOURCE: PNY flash drive
Plug it into your USB port on the computer, works like a mini hard drive sort of. When you plug it in, it should ask what you want to do, see files etc. Just drag and drop files in or out.
SOURCE: i just bought a pny 16gb usb 2.o drive to download
Is your memory card is recognize by windows or you didn't see it on windows explorer!
if you dont see it on explorer it could be solve by a service pack!
and if you see it on windows explorer but can't copy anything the card may be locked with the little tab on the side of the card!!
SOURCE: pny 16gb attachi flash drive reccognized by my
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
SOURCE: I have a PNY flash drive 2.0 g its read only
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
2. Format flash drive
