Question about PNY Optima 2GB USB 2.0 Flash Drive - Dark Red/Amber
I have a PNY flash drive 2.0 g its read only because of incomplete files cannot format
Posted by precisionroo on
laikexpert
    President:
  • 281 Answers
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format flash drive
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Posted on Feb 05, 2010
My PNY 32 GB Flash drive says 24 GB are being used, but all the files only add up to about 6 GB. How can I find those 18 GB worth of files, so I can use all the space on my drive?
Make sure nobody put hidden files on the Flash,
Copy the files off, then reformat the flash in NTFS unless you have an old computer.
FAT32 will work, the limit is 4GB for a single file and 2TB for the whole drive. If it was an SD or variation I would have kept with this for compatibility with cameras ect. NTFS for a USB has a couple features that make it slightly more reliable and faster for a situation where you have many small files.
Below is a link to a simple flash formatting tool.
HP USB Disk Storage Format Tool
Jul 20, 2016 | PNY Electronics - Others
WHY WONT MY 16GB PNY FLASHDRIVE WORK WHEN I DOWNLOAD A MOVIE ONTO IT?
Perhaps it has not been prepped, eg: not formated to use. Format it with fat32 file system using formatting software from the manufacturer. Also, make sure the movie file does not exceed 16 GB.
Apr 30, 2014 | PNY Attach? 16GB USB 2.0 Flash Drive
Usb problems, request format
This is a common request by Windows, so be careful as to not delete files. Try testing on another device that can read it, before you are forced to format
Dec 09, 2012 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
I can't format my PNY flash memory, and when it be connected to USB port the computer speed decreased. Heip me please.
Hi friend first you install yours device then logoff yours system then logon again and click on start--->run --> write command cmd then click on ok,Now write commands step by step
1) cd\ press enter
2) c:/>format drive letter (eg d: f: e: etc) press enter
3) read message carefully and then press y
now yours flash drive formatted
Aug 03, 2010 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
My card works I can take pictures just can't read them from my computer... computer wants to format disk then computer won't format. I have pny sd hc 4gb memory card
2. Format
Jan 31, 2010 | PNY 4GB Secure Digital High Capacity...
Downloaded Frostwire to USB Flash, can't delete Incomplete Folder
if you are the admin of the computer..you should be able cut it destroy it...but we are talkin about a 2 gb flash drive..if nothing is on it format the drive (if some files are on it click & drag files to pc...this is less then 10 min job and format the drive, then reinstall the data back onto the flash)...for future downloads and to avoid downloading to flash then pc...always check http://download.cnet.com/mac/?tag=hdr;snav
here you can review software, download software....this site will tell if what you about to download is worth the try or not.....frostwire and limewire are good and was no need to download on flash... my goal was to help 300 people with selected problems...you are the 3 0 0 th (and final)..i hope this is helpful to you ...keep the cnet link...thanks for being on FIXYA......(my closing to all those i've help) final line that i type here is .......Feel free to rate the help
Apr 19, 2009 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
Downloaded Frostwire to a memory stick, can't delete folder.
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Apr 19, 2009 | PNY 2GB microSD Memory Card
Windows says not enough space on pny 8 gig flash drive
Try formatting the drive as NTFS instead of FAT32 (assuming you are using it only on Windows computers). FAT32 doesn't support files over 4GB.
For more info, see http://www.google.com/search?q=fat32+file+size+limit
Feb 08, 2009 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
Write protected and locked files on PNY Optima 2 GB flashdrive
is there a little switch on the side of the usb, if so move it. test with "H2testW"
Jan 25, 2009 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
PNY Optima 2GB USB 2.0 Flash Drive - Dark Red/Amber Logo
695 people viewed this question
Top PNY Electronics - Others Experts
Marvin
Marvin
Jax Planet
Jax Planet
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
