How to remove Cadillac srx center console
Open the lid fully, you should see small hold down bolt heads, maybe 7 mm...these must come completely out, be sure to label as length etc is important. There are also 2 front connectors to the lower dash, but depending on your need to remove, you may not need to remove these...you probably need to remove the gear shift knob to raise the console...look directly under the knob...sometimes a small pull out clip to release the knob, sometimes a allen head screw to release...hope this helps.
