How can I reset the drum counter?
Hello good afternoon, friend u can give a hint of how I resouvo the problem of drum printer oki 431dn + b, pending
Fuse chip reset 65mA
Toner do drukarki materiay eksploatacyjne Oki reset bbna drum
SOURCE: Hi, recently bought an Oki c710 printer (not the
Try this:
While printer is off, hold down plus "+" and minus "-" keys then power printer on and continue to hold the + and - keys until "System Maintenance" appears on the display (you will see "please wait", "initializing", "ram check" before it appears).
When System Maintenance appears press Enter. You will be prompted for a password. The default password is "000000" (six zeroes). [Use the minus key for quicker access to the zeroes and press enter twice after the last zero to enter the menu.]
SOURCE: how do i reset the drum unit on my oki c710?
When the image drum cartridge reaches the 90% point of its life cycle on an Oki Data laser printer, a "Change Drum" message will display on the screen. Around this time the print typically starts to become faint or starts to deteriorate. When a new drum cartridge is installed, the drum cartridge counter needs to be reset for the printer to keep track of the life cycle of the replacement.
1.Turn the printer power off. Open the top cover.
2.Press the oval switch on the operator panel. Hold the switch down. Turn the printer power on.
3.Release the oval switch when the lights on the front panel flash twice. This indicates that the drum counter has been reset. Close the printer top cover.
SOURCE: am replacing my new yellow
Often this is caused by an aftermarket (rebuilt) drum. They simply didn't reset the chip counter. If this is a factory made drum then the problem might be caused by a bad or damaged sensor. Either way call your dealer and they can fix you up with a solution. I also find Okidata tech support to be quite helpful in answering these questions.
SOURCE: OKI C8600 Replace Image Drum - 563: K Drum Life
Solution:
