1986 Honda GL 1200 Aspencade Gold Wing Logo
Posted on Jun 30, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Regulator/rectifier connections gets hot on 1986 goldwing 1200 sei
Voltage goes up and down,,depending on rpm.Connecters for regulator/rectifier get unusually hot.Battery voltage decreases the longer you run the bike.
  • jimhr10
    jimhr10 Jul 09, 2015
    Hi bscruggs5, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What are the voltages? What is the maximum, minimum? The connections will get hot under normal operation.
Stan Ford
Level 3:
Genius:
  • Honda Master 3,131 Answers
  • Posted on Jul 10, 2015
Stan Ford
Honda Master
Level 3:
Genius:
Answers
3131
Questions
Helped
905692
Points
9078
Normal for voltage to increase with RPM, normal for voltage to decrease as battery reaches fully charged. make sure connectors are clean and tight.
5 Related Answers
Anonymous
  • 221 Answers
  • Posted on Jul 31, 2009
SOURCE: wire connector between stator & voltage reg/rectifier burnt
your voltage/reg. can be tested in a couple different ways check ground res. check res. then revs. bias on diodes you have ac in dc out it sounds like you may have a diode gone bad allowing ac curent to flow causing the wires to get hot
Anonymous
  • Posted on Jun 14, 2009
SOURCE: All lights dim, when applying brakes
when the lights dim is the bike idleing or is it above 2000 rpm if its ideling its not producing enough power back to battery so it will dim the lights. rev it up a little and see what happeneds
Anonymous
  • 66 Answers
  • Posted on Aug 15, 2009
SOURCE: my battery is not charging when bike is running (gsxr 600 k6 )
When you put a voltmeter across the battery terminals, you should get >13.5V (typically) with the engine running.
If less than this then your charging system is faulty and your battery will not charge.
See this personally authored thread for a diagnostic guide on how to determine whether you have a problem with your stator or Rectifier/Regulator - inlcuding some cold resistance checks you can do on the R/R to determine if it is shorted.
[url]http://www.triumphrat.net/speed-triple-forum/104504-charging-system-diagnostics-rectifier-regulator-upgrade.html[/url]
It was written initially for Triumphs, but applies to ANY 3-phase motorcycle charging system.
swDemonDog
  • 233 Answers
  • Posted on Oct 10, 2009
SOURCE: Can a voltage regulator/rectifier if not working
YES!
Good link here:
http://www.flygenring.dk/yamaha/artikler/1100ChargingSystem.pdf
Symptoms:
Lights flickering at times and/or battery gets hot to the touch
Problem:
Reglator/Rectifier
When the regulator dies, it allows as much as 19 volts to appear across the battery. This is not good. It will cook the battery and the battery could even explode. Fuse can not stand up to this!
heimlich
David Belcher
  • 1978 Answers
  • Posted on May 23, 2010
SOURCE: what is the torque specs 86 goldwing 1200
6mm bolts
ft-lbs 7-10
8mm bolts
ft-lbs 37-40
What is the location of the fuel pump relay on a 1987 Honda GL1200
Dont Relpace Your Goldwing 1200 Fuel Pump right away ...
? 10:57
https://www.youtube.com/watch?v=pcEeGhvPxq4
Sep 18, 2012 - Uploaded by dawino6260
just a heads up, unless you have the fuel pump relay jumped out, it will not .... Honda Goldwing gl1200 Single Carb Coversion and Alternator ...
Gl1200 checking fuel pump relay - YouTube
? 0:21
https://www.youtube.com/watch?v=o2Kb16Iw3pw
Jun 12, 2012 - Uploaded by virgilmobile1
Gl1200 checking fuel pump relay ... Pt.2 1986 Honda XL600R How To Replace The Fork Seals - Duration: 8:56. by D-Ray Smith 20,179 views.
Location of GL1200 pump relay - Steve Saunders Goldwing Forums
www.goldwingfacts.com > ... > Forums > Goldwing Technical Forum
Oct 6, 2012 - could anyone tell me were the fuel pump relay is located on 1984 gl m1200 carburated . thanks. ... Model: 1987 GL1200 Interstate 280,000 miles. Posts: 13,512 ... ry=MOTORCYCLES&make=HONDA&year=1984&fv eh=3442 ... GL1200 SEI Fuel Pump
Nov 24, 2015
Fuel pump relay location on 1985 GL1200 Interstate?
Mar 22, 2015
1987 gl1200 SEI fuel pump psi?
Apr 1, 2014
GL1200 Fuel Pump
Jun 26, 2011
More results from www.goldwingfacts.com
What causes a 1986 goldwing 1200 sei to idle fast then slow
Are you using premium gas? Lower octane, especially "oxygenated" which is a fancy name for selling you 10% less gas replacing it for cheap alcohol; burns hotter and can cause this.
It's a carb-fuel problem most likely.
Sep 26, 2014 • Motorcycles
1helpful
Suzuki 1986 intruder red light on dash
Check the battery is charging correctly. the voltages at the battery should be engine off- about 12.4 volts DC . Engine running at about 1000 rpm the voltage should be about 14.4 volts DC. if these voltages are down, you have a regulator, rectifier or alternator problem.
Put new battery on my 86 honda goldwing gl 1200 sei turned on key just show 11.9 volts with engine off or running. Is it a problem with the battery.
While running take a volt meter and see what voltage is should be 13.50 If not might be statter or voltage regalater Battery is ok It has charging problem MOPAR KENNY
2answers
Battery not charging
run an ohm test on the stator wires, make sure you get readings through all combinations of any 2 wires. if you don't get an ohms reading between 2 wires that means you have a broken stator winding and the stator needs to be replaced. hook up a volt meter to your battery and test battery voltage at rest (bike off), at idle (bike on and idling should be at least 12.5 - 13 volts), and steady around 3 - 4000 rpms (should be around 13-14.5 volts. if it exceeds 15 volts your regulator is bad and needs to be replaced. if all numbers are about what I said, have your battery tested. If your battery is over 1.5 years old it should be replaced anyway.
1helpful
1986 sei 1200 goldwing It will start from ignition on,fuel pump runs for a few seconds,fuel light goes out,every thing normal-no LED diagnostic lights.When it starts it will run for about 3-5 seconds &...
check the fuel filter it sounds like it's pluged and causing too much back presure this is causing an over load in the fuel pump causing it to stop working or to presure lock
Top Honda Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
Mike Cairns
Mike Cairns
Are you a Honda Expert? Answer questions, earn points and help others
