I have installed intenal web cam and microphone in this laptop. the camera works fine but the microphone does not.
Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or
select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or
select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
also
click start control panel sounds and audio devices then select voice then select volume from the microphone you can increase the volume or you can test your hardware in XP in
W 7 click start control panel hardware and sound manage audio devices recording right click on microphone you can configure speech recognition
or
you might have to boost
hope this helps
SOURCE: Camera assistant software not working
I have the same problem and i just want to know how to fix it.
SOURCE: my toshiba web cam is not working,
Windows Vista has compatibility issues with many webcams because the ACPI is different; need to know the make/model of your webcam.
I am assuming you have a Chicony USB 2.0 Webcam made by Toshiba...
CHICONY USB WEBCAM DRIVER
Aditional Toshiba Support for Webcam Hardware
SOURCE: problems with web cam on Toshiba netbook nb200
update the program ...if the webcam works fine on other IM programs ..it means that the msn is the problem ...
SOURCE: compaq presario v3000 internal microphone not working
hi
this is gopal from hp did you see that the microphone is working or not means the hardware not the software.
i also have installed windows 7 home editon on it, and the driver for internal microphone does not show anywhere not even a question mark.
