How do I get pictures from an interal memory Easy Share C143 on to a disc.
Hi.
Enter main menu, scroll down to "Setup Menu" and then navigate to "FORMAT". Simply format your internal or external memory, and thats it.
SOURCE: Trying to transfer pics on internal memory to my SD card.
Set the image storage setting of the camera to Internal.
Once it is set to internal, put the card in the camera and press review.
Copy the pictures from the internal memory to the card.
SOURCE: have kodak easy share...how do i transfer pictures
After inserting your memory card into the camera, you should be able to transfer the pictures from the internal memory to the memory card. Choose the option to review your pictures and hit the menu button while reviewing the pictures. Within that menu, there will be an option for memory storage. Choose internal memory. Exit the menu and re-enter it while still in the review mode. This time, select the Copy To menu option to transfer your pictures to the memory card.
SOURCE: My kodak easy share internal memory is full I went
dont you worry about that, the only thing you need to do is to format internal memory., you can do this by pressing menu button then scroll down and look for setup then press Ok button.,
now under setup press down arrow again then look for the word format then press Ok button, and you need to select the internal memory to format., gudluck!
SOURCE: I have a Kodak Easy Share C310. It keeps saying
"internal memory card is full" There is no more space in the camera's internal memory. Your camera has 16 MB of internal memory. The number of pictures you can store depends on the Picture Size setting you have selected on your camera.The following are approximate number of pictures you can take at each setting: 4.0 MP: 16 pictures 3.1 MP: 18 pictures 2.8 MP: 20 pictures 2.1 MP: 29 pictures 1.1 MP: 48 pictures Internal Memory?the camera always uses internal memory, even if a card is installed. Auto (default)?the camera uses the card if one is in the camera. If not, the camera uses internal memory Image Storage Choose a storage location for pictures and videos. To correct the issue your getting follow this steps: 1.Press the Menu button. 2.Press to highlight the setting you wish to change, then press the OK button. - The settings you need to look for is Image Storage 3.Choose an option, then press the OK button. - The option you need to choose is Auto the camera uses the card if one is in the camera. 4.Press the Menu button to exit.
