SOURCE: Pioneer turntable Pl-560 and Pioneer Receiver VSX-D409
Magnetic phono cartridges like the one on your pioneer has an output of about .005 Volts, the standard inputs are looking for 1 to 2 volts for fulol out put, the phono preamp will step up the output voltage to 1 volt so you can play it thru a non phono input like Aux, tape or tuner.
Radio shack sells cheap ones and you will hear what you pay for.
I sell turntables and audio gear, check out www.soundsciencecat.com
Good Luck,
Neal Van Berg
SOURCE: Pioneer VSX-4900S Receiver Connections
I know this is an old post but run front speaker outputs to the inputs on the sub then from the sub to the front speakers. bam!! it should work
SOURCE: PIONEER VSX-1018AH NO SOUND OUTPUT
If this is a new hookup be sure this amp doesn't have pre-out/main-in jacks that may need to be bypassed. Otherwise, maybe look to see if any tape deck buttons are pushed. Good luck.
SOURCE: Good day, I bought a pioneer
First thing has it a sub phono feed on the rear normally black socket if yes then go into the amp preset /the speaker set up and either the level is off or turned down thats all it can be . check the 5.1 setup pioneer amps some models dont work in dolby 2 the sub socket also use good quality cables . how old is the amp just out of interest.
SOURCE: the power standby light doesn t go on when my my
that is becaus eit should only come on when on stadby
