20 Most Recent Pioneer DXT-2266UB Car Audio System Questions & Answers
This is a hotel version of the iHome iPL10 which has the Set Clock button on top. Instead, the set/sync button is on the back of the unit. This is typically covered by a plastic cover to keep guests from messing with the time settings on the clock. The covered buttons allow you to set Volume Limit: high or low, Time: set/sync, and Day Light Savings Time (dst) +1 -1 or Auto.
Since this is the hotel version, there is no User Manual on iHome's web site.
Pioneer... | Answered on Apr 08, 2017
See the connection diagram on page 11 of this manual.
Pioneer... | Answered on Apr 19, 2013
Hello Ron, your Pioneer, does not own a Factory Reset
The problem that has no sound in any of the speakers, probably is due to the integrated power circuit, is burned
It has in the same integrated circuit, the two audio channels
I suggest you consult a specialized technical service
I hope I can solve the problem
Greetings Franco Dosil
Hola Ron, su Pioneer, no posee un Restablecimiento de Fabrica
El problema que no tiene sonido en ninguno de los parlantes, probablemente se debe a que el circuito integrado de potencia, se encuentre quemado
Tiene en el mismo circuito integrado, los dos canales de audio
Le sugiero consulte en un servicio t?cnico especializado
Espero logre resolver el problema
Saludos Franco Dosil
Pioneer Audio... | Answered 13 hours ago
“no sound coming out from the speaker” Choose radio to see if sound produces from speakers. If no, check switching control (control which signal is inputted such as radio, CD and aux.)IC & its voltage as well as voltage & power amp, including their voltage supply. Don't forget to download pioneer XV-EV9 service manual. If it have a DSP, it is also need to be checked by an oscilloscope including DSP X'tal(crystal) signal I/O,clock signal such as, L/Rclock(LRCL), bit clock(BCK),audio clock(ACK), DATA I/O.
Pioneer Audio... | Answered on May 04, 2019
Hello Warrior, for what you describe you want to connect to a Pioneer Vsxd 901s, an equalizer and this to two amplifiers, to give you an idea, I need you to describe the equipment you want to interconnect, brands and models and also comment what you want to achieve to be able to advise you in the best possible way
I await your response with the information of your teams
Hola Warrior, por lo que describes quieres conectar a un Pioneer Vsxd 901s, un ecualizador y este a dos amplificadores, para poder darte una idea, necesito que describas los equipos que quieres interconectar, marcas y modelos y tambi?n comenta lo que deseas lograr para poder aconsejarte de la mejor manera posible
Espero tu respuesta con la informaci?n de tus equipos
Pioneer Audio... | Answered on Apr 26, 2019
Hello Jade, so you describe there may be a problem in the Stanby circuit or secondary source
I am looking for the service manual of your Pioneer VSX-D702S and I can not find it, nor do I find information of that model, if with the models D701S and D703S
You could confirm the model of your Pioneer, to study the circuit and see the possibilities of failure
Send a photo of the front and one of the back
I wait your answer
Hola Jade, por lo que describes puede haber un problema en el circuito de Stanby o fuente secundaria
Estoy buscando el manual de servicio de tu Pioneer VSX-D702S y no lo encuentro, tampoco encuentro informacion de ese modelo, si con los modelos D701S y D703S
Podr?as confirmar el modelo de tu Pioneer, para estudiar el circuito y ver las posibilidades de falla
Manda una foto del frente y otra de la parte posterior
Espero tu respuesta
Pioneer Audio... | Answered on Apr 25, 2019
Hello Jim, if the components you describe bring the indication recorded on them, 2SB530 or B530 and 2SD370 or D370, are the output transistors of your Pioneer SA8100 and as you describe are mounted on heat sink (aluminum)
Ask, what kind of failure do you want to fix?
I hope that my answer help you
Hola Jim, si los componentes que describes traen la indicaci?n grabada en ellos de, 2SB530 o B530 y 2SD370 o D370, son los transistores de salida de tu Pioneer SA8100 y como describes est?n montados en disipador de calor (de aluminio)
Pregunta, que tipo de falla quieres arreglar?
Espero te haya servido mi respuesta
Pioneer Audio... | Answered on Apr 19, 2019
Hello Waseem, check that you have the connections between the Pioneer and your TV, so connect from the Pioneer's HDMI output to the HDMI input on the TV, with an HDMI-HDMI cable
Verify that the TV is selected for the Blu-Ray input
I hope you have luck in the checkup
Greeting Franco Dosil
Hola Waseem, verifica que tengas bien las conexiones entre el Pioneer y tu televisor, osea conectar desde la salida HDMI del Pioneer a la una entrada HDMI en el televisor, con un cable HDMI-HDMI
Verifica que el televisor se encuentre seleccionado para la entrada del Blu-Ray
Espero que tengas suerte en el chequeo
Saludo Franco Dosil
Hello John, to get sound in the "System B" really called "Zone 2" you have to select in the menu, which sound source will come out through this output and there you will have the solution
In the user manual it is well specified
Hola John, para obtener sonido en el "Sistema B" realmente denominados "Zona 2" tiene que seleccionar en el menu, que fuente de sonido va a salir por esta salida y ahi tendra la solucion
En el manual de usuarrio esta bien especificado
https://data2.manualslib.com/pdf2/44/4378/437730-pioneer/vsx1122k_operating_instructions.pdf?4c787a85640d8c79c964ed8b0fc26af7&take=binary
Pioneer Audio... | Answered on Apr 15, 2019
Hello Dennis, obviously you have a problem in the power supply or the power output stages, which is why the 1.25 A 125 V fuse is burned
Hola Dennis, evidentemente tienes un problema en la fuente de alimentaci?n o las etapas de salida de potencia, motivo por el cual se quema el fusible de 1.25 A 125 V
Hello Yokow, do a simple test, connect another set of speakers to the Pioneer team, if you see the high pitched sounds, the problem is in the speakers, in the same way, test the speakers on another equipment and listen to the result, there you will know where it is the problem
Hola Yokow, haz una prueba simple, conecta otro juego de bafles al equipo Pioneer, si te aparece los sonidos agudos, el problema lo tienes en los bafles, de igual manera prueba los bafles en otro equipo y escucha el resultado, ahi sabras donde esta el problema
Hello Nasir, obviously you have a problem in power supply or in the power output stages, since the equipment is being protected
Hola Nasir, evidentemente tienes un problema en fuente de alimentaci?n o en las etapas de salida de potencia, ya que el equipo se esta protegiendo
Hi, what do you need from the Pioneer vsx-530
Hola, que necesitas del Pioneer vsx-530
Hello Saleem, I sent you the link of a sequence of tests to verify the stages of your Pioneer XR-J11
Hola Saleem, le envi? el enlace de una secuencia de pruebas para verificar las etapas de su Pioneer XR-J11
https://www.hifiengine.com/hfe_downloads/index.php?pioneer/pioneer_rx-370_390_570_xr-j11m_troubleshoot_update_en.pdf
Hello Kevin, sent you the link of the user manual of the Pioneer VSX4800, there on page 22 tells you the steps for the tuning of stations and how to save them in the memories
Hola Kevin, te env?o el link del manual de usuario del Pioneer VSX4800, ahi en la pagina 22 te indica los pasos para la sintonizacion de emisoras y como guardarlas en las memorias
https://www.hifiengine.com/hfe_downloads/index.php?pioneer/pioneer_vsx-51_4800_4900s_4950s_en.pdf
Hello Kevin, as a replacement with the same format you have the following transistors 2SA1076, 2SA1095, 2SA1166 (A) PNP and 2SC2526, 2SC2565, 2SC2766 (A), 2SC2921 NPN
Hola Kevin, como reemplazo con el mismo formato tienes los siguientes transistores 2SA1076, 2SA1095, 2SA1166(A) los PNP y 2SC2526, 2SC2565, 2SC2766(A), 2SC2921 los NPN
Hello Dugen, obviously you have a problem in the function stage, it may be missing a voltage or you can have voltage leaks in the output amplifiers, you should check it with the service manual, if you have the knowledge and if not you have to take it to a specialized technical service
Hola Dugen, evidentemente tienes un problema en la etapa de funciones, puede estar faltando una tensi?n o puedes tener fugas de tensi?n en los amplificadores de salida, tendr?as que chequearlo con el manual de servicio, si tienes los conocimientos y sino tienes que llevarlo a un servicio t?cnico especializado
Pioneer DXT-2266UB Car Audio System Logo
Popular Tags
6 questions posted
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Pioneer Audio Players & Recorders
Most Popular Question
set time ihome hpl10
  • Audio Players & Recorders
