20 Most Recent Pioneer SX-315 Questions & Answers
With persistence, I was able to program the Universal Remote Control provided with the cable box to control my new used Pioneer SX-315 receiver. I now can control the tv volume, cable box, auxiliary stereo receiver with speaker system with one remote. Thank goodness I did not have to resort to buying a Pioneer remote control.
I was able to program another previously unused universal remote which I purchased several years ago. However, since the other remote control did not list the Vizio TV. That brand is too new for the remote.
Pioneer SX-315 | Answered on May 15, 2018
Music is not in DTS or Pro Logic, that is why.
Pioneer SX-315 | Answered on Jun 19, 2017
The bump may have broken or disconnected speaker wires.
Pioneer SX-315 | Answered on May 18, 2017
http://safemanuals.com/user-guide-instructions-owner-manual/PIONEER/SX-315%20-HTP-2500--_E
Pioneer SX-315 | Answered on Nov 23, 2016
more info pls
Pioneer SX-315 | Answered on Apr 03, 2016
the main thing to buzz is the power transformer does it work ?????
Pioneer SX-315 | Answered on Jul 21, 2015
Hi Tracey
Most of these older machine had speaker switches on the front panel. Can you check what they are set to. It may be that both switches(A and B) are set in, or set out. this could present the problem you are having with no sound. turn on just one switch that corresponds the connections you have made on the rear (use speaker A) Another thing to check, is when you first turn on the amp, do you hear a relay click shortly after you switch on. If you don't hear this delayed click, then there may well be a problem in the output stages of the amp. If this is the case, then you will need to take it to a tech to have a look and see what has failed in the amp. Hope this info helps, if you have any questions, I am happy to try and help you further.
regards
robotek
Pioneer SX-315 | Answered on Feb 12, 2015
Check the resistance of the primary on the main power transformer, (with power off) should be 1-3 ohms. If open you need a new transformer.
If good turn it on and check for ac voltage (120v) there.
Pioneer SX-315 | Answered on Feb 11, 2015
Hi Pete7591
It is more likely to be an output stage problem. The unit will be shutting down as a result if a DC offset in a faulty channel. You will need to isolate the problem somewhat to diagnose what is going on. Do you have a multimeter and a decent knowledge of electronics? If so, then I can talk you throiugh some things to check. If you dont think you are up to it, I would take it to a HiFi repair guy for a look.
It may be more worth your while to buy a refurbished unit here for $132.
I am more than happy to answer any other questions you may have about it, just give me a hoy :)
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Pioneer SX-315 | Answered on Jan 01, 2015
Very carefully prying apart at the seam however some damage is likely to occur the best tool I have found to use is plastic prying tool for auto door trim
Pioneer SX-315 | Answered on May 27, 2014
I think I just fixed a unit with the same problem. I opened the cover and found where the wire from the headphone jack plugs into a board just beside the power supply transformer. When removed, the unit appeared to select speakers as the output. Since the headphones are never used by the owner, I simply left the headphone cable unplugged. Unfortunately, I didn't have speakers to test it with but the unit appeared to be working correctly.
Pioneer SX-315 | Answered on Apr 10, 2014
Pioneer SX-315 Logo
106 questions posted
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Pioneer Audio Players & Recorders
Most Popular Question
yamaha rxv540 remote control power
  • Audio Players & Recorders
