20 Most Recent Pioneer PDP-5020FD 50 in. Plasma HDTV Questions & Answers
The short answer would be No to both questions, screens are highly technical in their manufacture and as a result make up between half and three quarters of a devices cost of TV's.
It will get worse sadly and end up as scrap or spares, screens do exist but mostly for say monitors or hand type devices (Tablets etc) but most I have seen are salvaged or "new" seconds that failed quality tests in some way.
Check your contents insurance for damage cover? to offset getting a new one.
Hope this helps............
Pioneer... | Answered on Aug 02, 2017
My pioneer 5020FD Kuro tv. when I plug power to the unit, a blue light blinks 8 times pause 2 sec. and blink 8 times repeating this and if i press power button it clicks red light and makes a clicking sound and goes back to the blue light blinking again, it did this once before and the picture came on fine until i turned it off and now it just blink the blue code.
Pioneer... | Answered on Oct 10, 2016
The blinking blue light may be signaling power supply failure.
Pioneer... | Answered on May 06, 2016
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and precious time.
Pioneer... | Answered on Aug 31, 2014
This model has no headphone out put. In the rear panel there are two monitor audio outputs which could drive headphones, but I think the volume output to a possible monitor matches the tv loudspeaker output, and may not turn off the audio separately.
Pioneer... | Answered on Mar 09, 2014
should have 4 screws on front of tv screan on coners or on back then you should be able to pull front of screan an replace the screan it just plugs in to the mother bord jesus loves u un plug it first
Pioneer... | Answered on Nov 05, 2013
Yes. It is.
Pioneer... | Answered on Mar 31, 2013
I also had this problem. I read elsewhere that this happens when your TV's audio setting are set to surround sound when you don't actually have a 5-speaker system. I changed the settings to regular stereo and it fixed the problem perfectly.
Pioneer... | Answered on Feb 25, 2012
Hi Miquel.
If the unit does not start but stays in standby with the red light on, then the TV is in forced standby mode because an internal problem has been detected.
Try disconnecting power cord for ten minutes. If that does not help, then the TV must be tested and repaired.
Regards.
Ginko
Pioneer... | Answered on Dec 03, 2011
I have the same issue - Pioneer told me the local repair shop could reset the firmware, I paid the $90 service call and they could not fix anything. For a 18 month old $5000 TV they now want me to replace the digital board for around $500.
Pioneer... | Answered on Nov 24, 2010
on some dvd players and surround sound systems have a thing called DRC (dynamic range compression) you can us that and it will help it a little. i have come across the same problem but im after a digital on to run with plex or vlc on a mac. im having to route it through protools to use a compressor on there, but thats eating my resources.
Pioneer... | Answered on Sep 29, 2010
One in panel on left hand edge, another 3 on rear.
Pioneer... | Answered on Jun 09, 2010
Pioneer PDP-5020FD 50 in. Plasma HDTV Logo
53 questions posted
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Pioneer Televison & Video
Most Popular Question
hdmi connection tv cannot
  • Televison & Video
