2008 Ford F-350 Logo
Dale Fleming Posted on Jun 15, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to repace the lower mirror
The passenger side door lower mirror is cracked. How do I get the old mirror off so I can install the new one.
Anonymous
Level 2:
New Friend:
  • Expert 118 Answers
  • Posted on Jun 15, 2012
Anonymous
Expert
Level 2:
New Friend:
Answers
118
Questions
0
Helped
65633
Points
352
May have to pull the interior door trim off to get to the bolts.
5 Related Answers
Anonymous
  • Posted on Jan 07, 2009
SOURCE: i need to replace passenger side mirror on 97 ford expedition
Both above answers are not right... I just replaced the Pass side power mirror assembly on my 97 Expedition. No heat, no directional.
The inside door panel must come off.
1. pry off interior triangular plastic trim piece inside of door at mirror area. Remove door panel screw at this area.
2. Pry off power window switch panel and remove door panel screw at this area.
3.Remove interior door light cover and remove screw at this area.
4. Remove plastic cover at door handle.
5. The interior door panel can now be lifted up to release it from it's fasteners.
6. Disconnect light and push power window switch assembly through the door panel and it can be set aside.
7. Disconnect mirror power at coupler.
8 Loosen three mirror mounting screws with 7/16 socket. DO NOT unscrew completely.. the will fall down the door cavity. Use a round magnet on holder to remove the screws completely.
9.Thread electrical connection into door panel and install mirror.
10. Smile when mirror works and drink a beer!
rayman
Anonymous
  • Posted on May 22, 2009
SOURCE: 2008 Ford Fusion Wing Mirror Replacement
I checked Ford Focus mirror replacement and it seems to be the same. This is for the manual, unheated mirror.
Remove the mirror cover inside the door - slide a screwdriver behind the cover and pry loose carefully.
Remove the single 10mm bolt and the mirror comes free.
NB. Do not drop the bolt into the door.
Anonymous
  • 60 Answers
  • Posted on Jun 21, 2009
SOURCE: Passenger side mirror replacement procedures
If its a power mirror there is more thing you will have to remove to get to the wires but if not there is a screw on the corner piece on the inside of the door. just pull the screw out and the bolts (3) that hold the mirror on are behind it. If it power then you will have to remove the door panel to access the wiring to disconnect it
Anonymous
  • 166 Answers
  • Posted on Jul 18, 2009
SOURCE: 2002 Ford Explorer - Drivers side door lock, rear
Aside from the fuses, your drive side power door lock may be failing to work because of a bad door-lock relay system, or, alternatively, the locking switch/button, itself, is not malfunctioning and in need of replacement.
A great handyman site that specifies the above probable causes and more is the following link:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Vehicle_Car_Zone_Cars_Trucks_Vans_Locks_Power_Locks_Do_Not_Lock_When_Pressing_Locking_Switch_Button.htm
Anonymous
  • 1986 Answers
  • Posted on Sep 29, 2009
SOURCE: how to install passenger side view mirror Ford
On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you'll need to manipulate the panel and disconnect the door handle linkage from the door handle and disconnect the wiring for your controls. Then you can access the bolts that secure the mirror onto the door
Heated Mirror on Passenger Side needs to be replaced. Mirror Part #91039AG02A. All mechanical features work, mirror is just cracked. How to install?
There should be a plug for the heater element. I think a new replacement comes with it, I am unsure. But just remove the old glass by using a screwdriver, wrapped in tape if you want, to pry it from the clips. The clips will release it, then unplug the heater element wire that is in the mirror. Plug the new mirror heater element, install mirror, it snaps into place, just give it a little pressure to make sure it is seated in the clips correctly.
1helpful
Do you need to remove the passenger side door panel to replace the outside mirror?
if the car has power mirrors then yes you have to remove the door panel to get access to the plug end to unplug the old mirror and install the new one. hope this helps
How do i install a new passenger side mirror on my 1997 cadillac deville
Remove the interior door cover and you should be able to access the nuts that hold the mirror in place. Remove the nuts and old mirror than install the new one and replace the cover.
1helpful
1helpful
Replacing Nissan Altima 1998 passenger mirror
to replace it you have to open up the door take off the little plactic piece in the corner of the door,, then there is going to be 3 screws that you have to remove in order to remove the old one, just do the steps in reverse to replace the new mirror, i just had the same issue, but on the driver side.. good luck
Need to replace passenger side view mirror 200 GMC Jimmy Diamond
On my '97, there was a triangular shaped piece of plastic on the inside trim that had to be removed. I think all three mounting screws were under that. It's been a few years, but I think that was how it was done.
I remember it was pretty easy though.
2004 Honda Accord Passenger Mirror
Lower the glass all of the way.
Carefully pry out the mirror mount cover by hand. This is inside of the door. Pry up from the bottom and pull out at the top.
Then unplug the electrical wiring harness clip.
Now take the three nuts off and hold the mirror once all three bolts are out the mirror will come right out.
2answers
How do I change the Right passenger side Mirrror does it just po
You need to take of the door panel so you can get to the attaching hardware to remove to old one. Do not cut the wires until you look inside to see if there is a plug to connect to the new mirror. the broken wires you are talking about will come off with the old mirror. I hope this will help you.
1helpful
4answers
Replace the review mirror
You need to remove the plastic plate that cover the mirror joint from the inside and undo the three bolts.
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
