CR2108087
Does it drain water? if soo then the agitator dogs are worn out,parts are cheap how to fix watch this video http://www.youtube.com/watch?v=C-HcsXQr1jM
SOURCE: Electrical Burning smell when agitating, trips breaker.
Send your complete model number, just to make sure we are working on same washer.
First check the lid latch switch by unplugging washer first and remove the font panel. Look up to where the switch is mounted. I am not positive that is your [problem but know there has been many problem with that switch. It will begin to melt ad cause the power to motor to be lost in a bad connection.
SOURCE: Roper washer RAX4232PQO doesn't agitate or spin
It sounds like you may have a broken motor coupling. This is a common problem that usually occurs through normal wear and tear. Replacement couplers are more resilient and resist breaking much better. If the washer will fill, will not agitate or spin, but will still drain, these are the symptoms of a broken motor coupling. The accompanying noise of the motor engaging and a rattling/grinding sound is also a common symptom. This is a very simple and inexpensive repair. The following link explains step-by-step how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The part number is included in the link I provided. You can purchase a replacement on line at appliancepartspros.com for about $11.
If you have any questions, please let me know. I hope this helps you.
NOTE: Roper is manufactured by Whirlpool and uses Whirlpool parts, so these instructions will apply.
SOURCE: Roper washer will not spin or drain-
you may have something stuck in your pump, preventing it from draining. The washer will not spin until it does drain. You'll have to empty the tub (you can do this with gravity by taking the drain hose and putting it down near the floor in a bucket). You will have to take the cabinet off, then take the hoses off the pump. Have some towels ready! Look inside the pump and hoses for an obstruction. If the fins inside the pump are damaged, you will have to replace it. If there is no obstruction here, look down inside the hose drain. Run a coat hanger down if neccessary to see if theres a blockage. The pump could be dead, too.
You could have a dead spot on the timer, but this is doubtful.
SOURCE: Hi, I have an Admiral
Feel the motor. If it is real hot after it quit it could be toast. Or something in the pump could have over heated it. Take the belt off and turn the pump to see if it is hard to turn, look in it to see if something got in it. Tip the washer back and you will see this:
Check the motor shaft for play or stiffness. If it works after it cools down then the motor overload tripped it. Might be the pump might not be.
Maytag product single belt washer service manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
